Question about Motorola MR350R Two Way Radio
My radios are only a couple of days old and in the middle of using them they both stopped transmitting or receiving they both come have the transmit tone but no thing is heard in the other they are MR350R
  • Motorola Master
  • 1,654 Answers
Check the settings of your frequency, interference eliminator code and Qt filter. These three must match identically on all your radios. For basic operation set the code and Qt filter to zero (off).
Here is a link to the user guide for more details: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
Best regards.
Posted on Aug 23, 2010
I have a Uniden UHF CB Handheld Model # UH076SX-NB. Have had it for 3 years and only used a dozen times. Now I can receive but unable to transmit. Any solutions please?
How do you know that the radio does not transmit? The batteries need to be fully charged, or new to transmit. The radio is old, and the cost to repair it may be close to how much a new CB radio is.
Good luck.
Aug 25, 2016 | Uniden Radio Communications
Can't transmit signal. Only get a 2 second beep when I push the transmit button
You have a poorly charged or bad battery. It takes more power to transmit than to receive. Usually the first thing you lose with a low, bad or poorly charged battery is transmit.
Try a known good battery in the radio. This should solve the problem. If not, check your battery contacts, as you may have one which is bad or not making good contact.
Clean your contacts with a pencil eraser to assure good connection with the charger.
Best regards.
Mar 18, 2014 | Kenwood Radio TK 260 360 270 370 2100 3100...
Doesn't transmit
Check your battery. Transmitting takes more energy than receiving. Also, check your frequency and code settings. The radio you are using this one with might have a different code setting than yours. http://shop.giantintl.com/Manuals.asp
Feb 13, 2014 | Motorola Talkabout T5720 (7 Channels)...
Radio will not send
It is possible your Code for transmit is different than your Code for receive. Cobra makes so many models, you are not giving enough information. Also, Transmit takes a LOT of power, so even if everything is setup, if your batts are weak or old, the radio will receive, but not transmit. Also check your antenna, make sure it is tight and NEVER transmit without an antenna. Yes, all lights will work even with old batteries.
Nov 10, 2013 | Cobra Radio Communications
Loud squeal/feedback noise when transmitting from a Kenwood TK-3230 to a TK-3400U4p
If you're close enough to hear the receive on one radio while transmitting on the other, it's good old-fashioned feedback. Turn the volume down on the receiving radio.
Jul 11, 2013 | Radio Communications
On my Cobra 25 LTD CLassic, New my meter drops when transmitting
is this a new out of the box radio?if so you might need a tech to look at it because it could be an internal problem.It would have to be put on an analyzer and a scope to actually be seen doing what you say.don't worry because it can be fixed.the cost of fixing it is the problem.You have to decide whether you want to pay more for the repair than you paid for the radio. Either way,new or used the answer is the same.
Sep 30, 2012 | Cobra 25 LTD 40-Channel CB Radio
T5100 : One radio receive but not transmit back.
check batteries, maybe they are on the way out. otherwise its in the lever connection. old?
May 07, 2012 | Motorola Talkabout T5100 (14 Channels)...
Hisses/squeals when transmitting
Check the input voltage into the radio while in transmit. The voltage maybe dropping as you go into transmit which causes it to drop into receive. That in turn allows the voltage to come back up. With your finger still on the PTT it tries to transmit again, etc. This could cause a feedback squeal and other symptoms.
May 30, 2009 | Uniden PRO538W (40 Channels) 2-Way Radio
Transmitting
Hello lstimpson,
You may have the CTCSS privacy code function enabled on one radio and not on the other. This function keeps your radio's received muted unless it receives a signal from another radio using the same privacy code. If you have Privacy Codes set for radio A but not for radio B you will still be able to transmit from A to B but when you transmit on radio B your signal will not be heard on radio A.
Make sure that both radios are set to the same privacy code or that the function is turned off on both radios.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 19, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Motorola MR350R  Two Way Radio Logo
262 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
