Question about Classic Electronics Merlin BIS-10 Phone (Refurbished, One Year Warranty)
How to program button for call pickup - Classic Electronics Merlin BIS-10 Phone (Refurbished, One Year Warranty)
If this is on a LEgend, Press intercom #9 and the extension number to pick up a call
Posted on Aug 24, 2010
How do I get my headset to work on NEC SV8100
to use the headset port you can program a button that toggles between the handset piece and the headset port (under the handset),
assuming that your installer has used standard feature codes, press the following;
? Press Speaker key.
? Dial 751.
? Press an available Function key. (one of your unused 24 buttons)
? Dial 05.
the Function button is now your Headset pickup/release button
Feb 26, 2015 | NEC Lands Phones
How to pick the call from other extensions
I have downloaded several manuals for the Avaya by searching online, some are good basic user guides and some very technical. You can pick up a call in several different ways - here is a copy from the manual on call pick ups:
2.2.2 Call Pickup
If you hear another phone ringing, there are a number of ways that you can answer the call if you know the user, group
or line being called.
1.If already on a call, end the call by pressing Drop or put it on hold by either pressing Hold or pressing the
button which the call is on.
2.Press an idle Intercom or Call Appearance button.
· To pickup a call ringing at a particular extension:
Dial 6 followed by the extension number at which the call is ringing or parked.
· To pickup the longest waiting call in a pickup group:
Dial 66 followed by the pickup group number (1 to 4).
· To pickup the call ringing on a particular line:
Dial 68 followed by the two digit line number.
3. You can continue the call handsfree or switch to using the handset or headset (press the HEADSET button).
To Create a Call Pickup Button (ETR 18D/ETR 34D Phone)
1.At the phone press Feature 00.
2.Program Extension: is shown on the display.
3.Press the button that you want to edit or enter a number between 03 to 80 to select a button. The current setting
of the button is displayed.
4.Press the first intercom or call appearance button.
5.Dial 6 followed by the target extension number.
6.The button function is changed to Call Pickup followed by the target extension number.
· Exit programming by pressing Feature 00. You can also exit programming mode by lifting the handset, then
placing it back in the cradle.
To Use a Call Pickup Button
1.Press the Call Pickup programmed button
May 29, 2014 | Avaya Corded Phone avaparp18d
How do you set the phone to automatic pickup a ringing phone line when you lift handset?
If the ringing line is programmed into one of your dss/blf buttons it should answer when you lift the handset. Else, if it is someone else's phone ringing, lift your handset and dial 40. That will only work if allowed in the pbx programming. Hope that helps.
Mar 07, 2013 | Panasonic KX-T7453 Corded Phone
Programming pick up key
Need to login to the phone system and put both phones in a pickup group or program buttons on the phone of the other phone.
Jan 12, 2012 | Mitel 5212 IP Phone
When i pickup the phone i want the intercom to be my first option not a line out?
One of the following two methods of programming "Preferred Line Assignment-Outgoing" should work depending on which Panasonic phone system your KX-T7433B phone is connected to. Try number one first, if PROGRAM 99 does not get you into station programming, try number 2.
1) Press PROGRAM button then dial 99 to enter station programming. Dial 1, then press INTERCOM button to select Intercom as your Preferred Line Assignment-Outgoing choice. Press AUTODIAL/STORE button to save programming. Press PROGRAM button to end station programming or lifthandset then replace in cradle to end station programming.
2) Press PROGRAM button then dial 19, press AUTODIAL/STORE button. Press INTERCOM button then AUTODIAL/STORE button. Press PROGRAM button to end station programming or lift handset and replace in cradle to end station programming.
Feb 11, 2011 | Panasonic KX-T7433B Corded Phone
KX-T3250B; the 5 red indicators on the upper right corner are flashing...
these 5 leds lights when phone is out of program. every phone should have his own indicator showing (when handset is off) his position in chain of phones. to make them stop flashing do following:
1. push and hold "PROGRAME" button until "MUTE" indicator lights (you'll hear beep sound).
2. push one "1" to "5" button on numeric keyboard depending on telephone's position in chain (must be unique).
3. push "MEMORY" button.
Now when you pickup handset only one indicator should light.
sorry, my English is not perfect :-(
Feb 04, 2011 | Panasonic Lands Phones
Changed batteries on my 04 2500 HD diesel pickup
if the heater vent door is not stuck then there should be a resetcombo with the buttons.
Oct 26, 2009 | 2002 Chevrolet Silverado 2500HD
Cisco 7970 ip phone, can't pickup call
Make sure you have both phones in the same call pickup group. I have never used the group pickup button. The regular pickup button is what I use.
Just to be clear the procedure is..once phone A rings you hit the pickup button on any other phone that is in the same group as phone A. After you hit the pickup button the call will be drawn to the phone that you hit the pickup button on. Once the call is on that set hit the answer button to answer the call.
Jul 10, 2009 | Cisco Computers & Internet
How do I program the keyless fob for my 1997 F250 pickup truck?
cycle the key on and off I can't remember if its 6 or 8 times. the locks should cycle up and down then press any button on the fob the locks should cycle again then turn off key
Dec 23, 2008 | 1997 Ford F250 SuperCab
Speed dialing
· Without lifting the handset, press redial button. Press the button on the strip you wish to store the telephone number on. Note that these 5 buttons are position numbers are 100, 101, 102, 103 and 104. 100 is the first button above EXT PICKUP, and 104 is the first button below DND. These numbers can also be programmed using the method in Step 2 below and entering the position number (100 – 104).
· Enter the telephone number. Be sure to program the 9 in front of all local numbers, and 9+1+(Area Code) in front of long distance numbers.
· Press redial.
· To use the numbers stored on these buttons, lift the handset and press the button.
Oct 29, 2007 | Toshiba DKT-2010 Corded Phone
Classic Electronics Merlin BIS-10 Phone (Refurbished, One Year Warranty) Logo
82 people viewed this question
Top Classic Electronics Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Classic Electronics Lands Phone Expert? Answer questions, earn points and help others
