Question about Zenith ZEN700 Remote Control
Code for from my Vizio 32" DTV -
Would you know the code for the vizio 32" DTV remote code, so I could program my new Jumbo remote. If you know the code I want to thank you for the info.
Aloha, from Maui - Nelson
  • djdirkes Mar 20, 2009
    I need the code for my 32" vizio tv
  • Dre68 Apr 05, 2009
    I need to remote code for my 32" vizio tv.
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
I need to program my jumbo universal remote the sharper image but can't find the instructions needed to use the proper code for a vizio 19 inc.tv
Hey neri melendez!
You can find instructions on how to program our remotes at this link: http://www.dishnetwork.com/SupportSection/remote-setup. Select your model of receive from the list and the PDF document will contain the instructions on how to program your remote in the future. I have provided the steps below for quick reference for you!
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
Let me know if you have any other questions!
Tommy Faust
DISH Internet Response Team
Nov 24, 2011 | Vizio Televison & Video
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
Jun 03, 2011 | Innovage Jumbo Remote Control
Just had a new vizio flat tv installed need to know program code for the tv to the receiver
Hello, Matt Gonzales with DISH Network here. The codes to program a 3.0 remote to a Vizio tv are 505, 627 and 671. If you do not have a 3.0 remote, or the codes provided did not work, you can find a full working list at http://tech.dishnetwork.com/departmental_content/techportal/index.shtml. Hope this helps.
Dec 25, 2010 | DISH Network 301 DTV Receiver
Having difficulty with a code for a vizio tv.
go to the following website and look at the manual. i do not see vizio listed as one of the brands, but there is a section on how to retrieve a remote code that may not be listed.
http://www.remotecodelist.com/remotes/innovage/Jumbo_Universal_Remote.pdf
good luck
Dec 07, 2009 | Big Button TV Universal Remote
Cannot program remote for tv
Here are the codes from Visio's tech support line:
These are listed in order of probability and are for remotes using four digit codes. Call them if you need a three or five digit code.
1758
0178
1756
0128
0117
1017
1078
0030
0056
0205
1292
Good Luck
Jan 03, 2009 | Vizio L32 32 in. LCD HDTV
Dtv universal remote
I'm using a universal remote with code for an LG 0178 (or 101780 AND IT WORKS
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Remote Control Code
42 " HDTV
using Bigmatters universal jumbo remote (ER04305J 07/07)
Hope you can help.
May 12, 2008 | Vizio L32 32 in. LCD HDTV
Vizio tv
i used the goldstar codes on my vizio tv and it worked
heres a list of codes
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, 172, 196
the code 004 worked on my 32' Vizio HDTV, for the Jumbo Universal Remote
Nov 23, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Zenith ZEN700 Remote Control Logo
671 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
