Question about Mansfield Plumbing Products Mansfield WaterSense Labeled QuantumOne White Elongated SmartHeight High Ef
Tank lid broken, how can I replace it. - Mansfield Plumbing Products Mansfield WaterSense Labeled QuantumOne White Elongated SmartHeight High Ef
    Scholar:
  • 122 Answers
Posted on Aug 23, 2010
My washer is not spinning
Hello there and thank you for choosing fixya
Normally this problem is due to a worn out drive /basket clutch assembly that has failed this assy is normally should be replaced as a set and not only 1 part because if you only replace the drive but not the clutch then the clutch will soon fail ok so i suggest replacing them as a set
Here is some more info on this below
Quick tips....Slow or no spin....
  1. Lid open.
  2. Lid switch defective. ( Very Common problem )
  3. Lid switch disconnect plug open/burnt.
  4. Clothes between basket and outer tank.
  5. Lint filter caught between the wash basket and outer holding tank.
  6. Wiring harness.
  7. Bad motor capacitor ( How to check )
  8. Weak clutch.
  9. Timer switches. ( possible not allowing the pause required for the transmission to set up to spin )
  10. Motor.
  11. Cam driver on basket drive broken or basket drive weak.
  12. Spin tube.
  13. Notches in drive block worn out and not engaging basket drive shaft.
  14. Broken motor coupling. See Replacing Motor Coupler Page
  15. Read a bit on how the washer works as well.
If your washer will not spin...first thing is to consider if washer is RUNNING and not spinning or NOT RUNNING and not spinning. If the washer is NOT running ( or working intermittently ) check lid switch for continuity. Broken lid switch arm and the lid switch probe should be checked as well. Something NEW to check for when looking at that lid switch. Always a good idea to check for clothing between the tanks as well. Make sure nothing has gone through one of the inner basket holes and is now scrapping or jamming the tub from moving, such items may be a nail, pin, bra under wire.
If washer IS running, remove power and remove cabinet. Use a piece of insulated wire to by-pass the lid switch wires, turn the timer to spin and pull out the knob, push the knob back in and pull it out again. Watch for the clutch drum to turn ( brown section in picture A ). If it is turning but the inner wash tub is not, then more often than not you have a worn clutch lining or a weak spin spring, also the brake may have seized up. If the clutch drum is not turning and washer is not spinning, often the failure is in the transmission gear box. ( see picture B ).
Apr 29, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Broken Tank Lid
the model # is inside the tank. take that number to lowes and they will order you a new one.
Dec 04, 2010 | American Standard 4110 White Toilet Tank...
Water does not get hot
There are several things that could be causing this - the thermostat, the limit thermostat, or the tank heater itself. You can start checking by unplugging the unit, then remove the screws from the lid. Carefully lift the lid until you can reach the wires going to the top burner. Pull these wires off, placing them where they won't make contact with the metal on the unit. Look inside the unit, and see if there are any wires burnt off. If not, look at the small limit thermostat that is located on the top of the tank. It's a little round white unit. Move it around, and see if it's loose or broken. lift the metal tab, and take the limit thermostat out. Many of these units break apart, and quit working. If it's broken, take the two wires off it, and replace it. If not, then it will probably the thermostat or the tank heater. To see which it is, take the wires off the tank heater -the two poles sticking out of the tank lid. Using a voltmeter, check for resistance across the two poles. There should be resistance there. Also, check for continuance from the heater posts to ground by placing one lead on the heater post, and touch the other to the side or top of the tank. If the needle moves at all, your tank heater is shorting to ground, and needs to be replaced. If these tests are ok, then the main thermostat needs to be replaced. Hope this helps.
Apr 30, 2010 | Bunn VPS Coffee Maker
Toilet lid is broken, is there a way to find a replacement
Any normal toilet seat may work, check your local Home Depo.
Mar 23, 2010 | VitrA Aria Toilet with Round Bowl /...
Water want stop pouring
remove lid from tank.see that 'flapper valve' in bottom of tank is seating to stop flow into bowl.adjust chain linking flapper to flush handle. replace worn or broken parts
Oct 01, 2009 | Toto Toilet Onepiece Ultramax ...
BROKEN fUEL TANK EXTERIOR METAL LID
Just the metal lid is available through the dealer for about $25.00 Part # 63910-S02-A00ZZ. However a new lid comes in black primer and would need to be painted, this would cost approx. $50.00
A 2000 civic is a pretty common car. If you call a few salvage yards in your area, I am sure that someone will have one in the color you need for about $25.00 +shipping.
Sep 10, 2009 | 2000 Honda Civic
We have a broken tank lid and need to replace it.
Try your local plumbers merchants [u need the make of the toilet] or thy local salvage yards www.salvo.com could be helpfull
Always take the broken lid with you
Sep 07, 2009 | VitrA Aria Toilet with Elongated Bowl/...
Hoover SteamVac Model F6056-900 SteamVac/SpinScrub. Indicator light and high pitch suction noise indicates that dirty water tank is full. However, water level indicator (yellow bobbing plastic thing) is...
There are 2 filters, make sure they are clean, one is on the tank lid, the other is from the bottom, it is red, pull it out and clean it. If yours has a foam filter on the tank lid covering the yellow ball, make sure there is at least a 1/4 in. gap from the top. Also make sure that the lid in on and secured tightly.
May 26, 2008 | Hoover Vacuums
Mansfield Plumbing Products Mansfield WaterSense Labeled QuantumOne White Elongated SmartHeight High Ef Logo
Top Mansfield Plumbing Products Home Experts
jdthefixer
john h
bobalix
Are you a Mansfield Plumbing Products Home Expert? Answer questions, earn points and help others
