Question about Sony Playstation 3 (PS3) Console
Play station is hooked up on turned on (blue light) tv is on and on the right input but nothing shows up on the screen. Please help
    President:
  • 1,139 Answers
Please try these easy steps to sort your problem out :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Posted on Aug 23, 2010
All my tv shows a a blue screen nothing else even when I press input
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 14, 2015 | Televison & Video
Hi we have lost all channels of our hisence tv just blue screen saying no signal please help had channels yesterday
Nothing to worry, You change to AV mode to TV mode and wise verse,
If nothing happen then call the service center, It only two months old.
Jul 23, 2012 | Hisense LCD1504 15 in. Television
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Off air antenna hook up
You probably have to set the tv to run on the input jacks your antenna is plugged in to. In other words these newer tv's have 2 or 3 inputs and they only run on the input it is set on, if not the right one you must change the setting. On mine there is a button next to the on/off button on the set which is inputs, keep pressing that button and it cycles through inputs till you get the right one. When tv first comes on it flashes the name of the current input on the screen--think they all do that. If input is hdmi, it refers to the hdmi socket, if composit (I think) then it refers to the rca jacks that are red, white, yellow, may be more than one of either. In this way you could have cable on one input, a video player on another, and cable on still another by switching desired input. I use a UHF antenna but it didn't work till I got the right input and then searched for stations studying the menu for station setup, have to set up the stations first, it will configure settings for each station, and have it do that before you can expect to find and receive stations. With correct input you should get a blue screen or something with printing if input is right, click your menu button and will see the menu and then find where to configure stations setup, otherwise it is totally black and nothing happens, nothing responds, that's the wrong input.
Jan 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Playback
when I plug in the RPU DC cord from my camera to the input on my tv I get nothing. Is my input jack bad or what. Also, if I tried the s video jack from the camera to the tv, would that work??? I don't know what the AV out jack is for I don't have a cord for that
Nov 12, 2008 | Sony Handycam CCD-TRV308 Camcorder
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Sep 08, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Sony Playstation 3 (PS3) Console Logo
21 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
