Question about Ovens
KENMORE GAS RANGE MODEL#36275528000 OR 72321 S/N 2012331622 BOTTOM OVEN BURNER LIGHTS UP FOR 10 SECONDS AND THEN FLICKERS AND GOES OUT
  • 1 more comment
  • rgidy1 Aug 23, 2010
    THE KENMORE RANGE HAS A GLOW PLUG. THE BURNERS ON TOP WORK FINE . IT'S THE OVEN BOTTOM ;BURNER THAT GOES OUT AFTER TEN SECONDS THE TOP BROILER BURNER WORKS FINE
  • rgidy1 Aug 24, 2010
    KENMORE GAS RANGE MODEL36275528000 BOTTOM BURNER IN OVEN WILL LIGHT UP ABOUT 10 SECONDS AND WILL FILCKER AND GO OUT
  • rgidy1 Aug 25, 2010
    CAN I TAKE THE BROILER IGNITOR AND PUT IT ON THE BOTTOM BURNER TO SEE IT THAT IS THE PROBLEM.
  • 905 Answers
This could be a failure of the control valve for the oven, or it could be a failure of the secondary regulator. Here's how to find out:
Check 1:
Try to light all of your surface burners. See if there is a decrease in flame intensity as additional burners are turned on and lit. It is not normal for flame height to decrease. If this happens, then the regulator is faulty.
Check 2:
With the above burners on, turn on the oven and let it light off. Watch the surface burners for a change in flame height when gas begins to flow into the oven and lights. If the flame for surface burners does not change when oven lights and then flickers / goes out, then the oven gas control valve is at issue. If the surface burners have a decrease in flame height when oven comes on / flickers out, then the regulator is at fault.
If the flame height on the surface burners does not change when oven is turned on, it may also be that the temperature sensor is not detecting an appropriate rise in temperature, but this is unlikely and would have presented previous symptoms of the oven having tendency to burn foods, or not cook very quickly.
Posted on Aug 25, 2010
  • Ovens Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description I suspect you have a faulty bake ignitor. This may surprise you, or it may not. I think at first it surprises people when the hot surface ignitor glows but the oven either will lite but go out shortly after or won't lite at all.
Since the ignitor "glows" one figures it would appear to be working, that would be wrong. These ignitor's serve 2 functions, first it need's to maintain a set value to open/activate the gas valve, typically around 3.5amps... & 2nd Ignite the fuel once said valve is open.
A poor/faulty ignitor may glow & and even ignite the burner intermittently for moments at a time ( thus giving off some heat but never the set amount or not at all ) but yet not reach the needed value to open the valve consistently nor adequately, hence the need to replace the bake ignitor.
Try this ( replacing the hot surface ignitor ) and I'm certain you'll be up & running and as they say " cookin' with gas" !
**Be sure to unplug the range and turn off the gas before performing any service to the unit...safety first**
I`d also suggest you try the oven on just “broil” as well to insure that ignitor is ok.
You should refer to your specific model when ordering the part locally or on-line. The most common hot surface ignitor part is #12400035 (see image ) and it pretty much fits everything, but your ignitor is WB13K21.
Either one is made by "Norton" as most are. The first is a Maytag/Magic Chef part number, the second ( yours ) is General Electric which is the manufacturer of your Kenmore.
KENMORE GAS RANGE MODEL#36275528000 OR - ffc4483.jpg Try places like repairclinic.com, searspartsdirect.com, appliancepartspros.com etc.
Thanks for visiting "fixya", let me know if you require further assistance and good luck.
Macmarkus
  • Ovens Master
  • 8,220 Answers
It could simply be a bad ignitor and that is what is bad 99% of the time. You ain't posting any error codes so the brains must think everything is ok.
Posted on Aug 24, 2010
  • 2,272 Answers
There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.------------- The other possibility:-------- The problem caused by the gas safety valve.
This part is not too difficult to replace yourself. You need two adjustable wrenches and a screwdriver.
Do not forget to shut off the gas and remove the power first.Or the faulty Igniter.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 23, 2010
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
Kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Gas Oven not working
IT POSSIBLY DOES IF SO IT WOULD BE UNDER TH BOTTOM PAN USUALLY IN THE BOTTOM OF THE OVEN , YOU WILL NEED TO LIGHT IT WITH A MATCH (AFIREPLACE MATCH WORKS BEST ) LET BURN FOR A FEW MINUTES TO MAKE SURE IT GOING TO STAY LIT BEFORE YOU TRY THE OVEN .
Nov 26, 2008 | Ovens
Oven does not heat up, can smell gas.
You probably need an oven igniter, it's weak. Remove oven bottom and find caged unit attached to burner. Replace this oven igniter. The 2 wires can go either way.
Nov 22, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
97 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
