Question about Yamaha PDM-1 50 in. Plasma Television
Samsung PSN4231 works for a couple of hours, then screen fades until black...sound still on. If your turn off for about 30 seconds then turn on again picture comes back and last about 5 minutes and turn it off and on again will bring back picture for about 5 more minutes. Before picture goes black sounds like a fan goes on.
  • 979 Answers
SOURCE: sound turns on and off intermittantly through unit
You may have a bad protection relay or solder joint at the relay mount position. This relay prevents power supply "thumps" when the unit is first turned on, and also shuts the amp down when there is an overload problem....accordianman
Posted on Jun 20, 2008
  • 11 Answers
SOURCE: I've got Yamaha Fazer 600. The engine cuts off
MAN ITS A MINOR PROB JST CHANGE THE SPEED OF COMBUSTION IT SHOULD BE 1 MIN AT UR RPM METER IN THE BIKE AND ITS PIN IS NEAR THE CARBURATER JST CHANGE IT AND ENJOY UR RIDE
Posted on Aug 25, 2009
  • 87 Answers
SOURCE: My AM radio reception does not work. I have a loop
You should buy an antenna amplifier. Here are some that work in-line and are designed specifically for AM radio:
http://www.google.com/products?q=AM+antenna+amplifier&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&ei=sVRBTKGhD47msQOvpNCYDQ&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CDEQrQQwAA
Posted on Jul 17, 2010
elshaddai159
  • 1016 Answers
SOURCE: The unit has operated flawlessly
This is your sound processor in the unit, which unfortunately is non repairable.
You may still be able to replace the motherboard, but due to it's age this may not be possible anymore, good luck with it.
Thanks
Jason
Posted on Oct 26, 2010
SOURCE: was working fine. next day won't turn on at all.
I have the exact same issue, except that it sometimes turns on (very rarely though)
Posted on May 28, 2011
Plasma TV has a black uneven splotch in the middle of the screen
hmmm. sounds like the screen might be damaged. You might have to get a new one. But before you do that I would try leaving it off for a while maybe a few hours or so and see if that helps.
Jul 10, 2017 | Televison & Video
Sony KPR-53EXR15 pictures fades in and out
Sounds like possibly it could be connection related between any AV/Cable ports. Worst case would be the capacitors of the motherboard leaking. It's possible to fix anything. Just make sure you have the knowledge and the right equipment.
Mar 31, 2017 | Televison & Video
Screen stays black
There are two possible causes of the problem:
1. Power issue - the battery could have a problem and it could only give power when you turn on the phone, but it could no longer provide ENOUGH power to make the phone works for couple of hours.
2. Firmware/Software issue - this is a common symptoms if an electronic device has a corrupted firmware or software.
You may try to replace the battery first, and see if that's causing the problem. If same problem occur, then you need to contact the manufacturer and have them re-program the phone. And that should work correctly.
Thank you and good luck!
Jun 13, 2010 | LG Dare VX9700 Cell Phone
Samsung Model HLR4667WAX/XAA is making a buzzing sound
This TV is horrible. I have the same one and not even a year replaced the light bulb twice. Very disappointing for a Samsung.
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Nov 01, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
245BW monitor not working (stranges colors ad aeternam...)
I had the same problems as almost all of these people and the answer seems to be that I uninstall the current Nvidia Drivers and use a previous set. The 169.28 were a real problem for me. Just when I thought it was working I would get the strange wash out and I could not turn it off except with the back power switch, aslo using the DVI turns off all the on screen controls.
Good Luck
Dec 27, 2007 | Samsung SyncMaster 245BW Monitor
Yamaha PDM-1 50 in. Plasma Television Logo
200 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
