Question about Honda 8 HP Engine
Gx240 honda engine starts fine, but coughs and sputters with heavy exhaust; then it runs smoothly for 2 to 3 seconds and then shuts itself off. I checked and there is plenty of gas and the correct amount of oil in the engine.
  • 395 Answers
Sounds like it could do with a cleanout of the carburettor. Also check for dirt/rust in fuel tank that could be restricting fuel flow to carby.
Posted on Aug 24, 2010
Engine keeps running after key is off
Could be what is called "dieseling" where it sounds like a diesel truck.
Possible causes are a heavy carbon buildup in the cylinders, or the idle speed could be too high.
Apr 21, 2013 | 2006 Chrysler 300
Car starts running rough at idle, eventually quits running. Has new plugs, wires, cap, fuel pump, fuel filter, air filter, IAC Valve, and gas cap.
Back then, Honda suggested timing belt replacement every 60,000 miles. If your Honda has that much mileage or more and has never had the belt replaced, now may be the time.
Sep 11, 2012 | 1995 Honda Accord
Oil comeing out exhaust and gas in oil but runs for a few minutes and shuts down
sounds like the needle valve is not seating and over flowing the fuel into the crankcase change the valve and seat then change the oil a couple times
Apr 27, 2012 | Honda Horizontal Engine 8 HP OHV 2:1...
2003 YZ250 engine coughs and sputters at high RPM
You have a slightly gummed up carb. I would get a can of carb. cleaner that you add to the fuel and hope that running that through the carb in a couple of tanks of gas will solve your problem.
Jun 18, 2009 | 2003 Yamaha YZ 250
I just had my muffler/exhaust system changed at a garage. Before I brought the car in it was loud, but otherwise ran fine. Since I picked my car up I have noticed that now it struggles to reach cruising...
first of all , i would say check your oil pressure.second i would take a look at your oil pan and the screw that holds it together.because some times they put them on too tight scripping them,that can make it do most of the things you described above.or if its not tight enough,it could do the same. i hope i was helpful in some way. good luck
Apr 14, 2009 | 1996 Mitsubishi Eclipse
Engine shutdown.....
OK, fast! Check the exhaust for rotten egg smell and pressure. Exhaust should stop immediately when engine is turn ed off
Apr 12, 2009 | 1993 Buick Century
Engine coughs and sputters, won't start
its sounds like it has jumped time
you might want to check that
Sep 23, 2008 | 1998 Ford Explorer
Honda 8 HP Engine Logo
430 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
