Question about True T-49 Side by Side Refrigerator Commercial
TRUE MODEL T-49 RUNS AT TOP OF GREEN TEMP ZONE. ICES UP AND TRAY RUNS OVER. ICE HAS BEEN REMOVED 2 WEEKS AGO. I NEED TO KNOW HOW AJUSTMENT #'S REFLECT TEMP UP OR DOWN ?
    Novelist:
  • 112 Answers
Generally set at 3 to 5 - with 5 being colder. Most of my customers run on 5.
Posted on Dec 12, 2010
Ice forming in drainhole at rear.Have cleared it with curtain wire but re-ices and water runs down into cabinet
You have to keep that zone clear of all items being stored by at least 2 inches. That is a drain for water in a liquid state after a defrost cycle. Without some air circulation the temp is low enough to turn some of it solid before it can escape...then it snow balls and like snow flakes just gets bigger til it plugs. It's a design flaw and there's more bad news. The pipes inside that carry the coolant are so thin just moving the unit can cause a break and that is when you have to buy a new one.
Mar 05, 2017 | Refrigerators
The drain pan is dry. There is ice buildup on the top half of the defroster. The compressor runs nonstop. The temp doesn't get any cooler than 45. The condenser is clean enough to see through and the door...
Is the evaporator fan motor running? If it is only running at half speed or not at all, that could explain the ice buildup. If the coils are icing up because of no air flow over them, then the defrost heater stays on, trying to get rid of the ice.
Sep 14, 2013 | True T-49 Side by Side Refrigerator...
Refrigerator Model TFX22KRDA. The evaporator located in the freezer ices over and loses cooling capacity. When turned off and the ice is removed, the freezer and refrigerator both work fine for a few weeks...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 29, 2010 | GE Refrigerators
Water is leaking down through what i am calling the vent in the top of the fridge inside and it is building up over a few weeks and then it runs out on the floor.
I have experienced this very same problem before. There is a small condensate drain hole in the rear of the freezer compartment on some model refrigerators. If it ices over, the condensate has no where to go but down through the louvers and into the refrigerator compartment. It usually drips from the center overhead area down on to the shelves and accumulates in the bottom until it runs out the bottom of the door.. One way to tell is to check the back of the refrigerator to see if there is a visible drain line (larger in diameter than the ice make water line) that runs from the freezer compartment down to the compressor area. You may want remove everything and defrost the freezer and see if the problem goes away.
If you have questions/concerns, please post back with your MODEL NUMBER and let me know. I hope this helps you.
NOTE: Even if this is a frostless refrigerator, I have experienced the problem where ice can build up and plug the drain. You may have to remove the bottom tray in the freezer to access it.
Aug 27, 2010 | Microwave Ovens
1 week old Whirlpool Gold refrigerator. model FI7FVCXWYO ice make
Call for service as the "wet ice" indicates freezer is warm.
May 20, 2010 | Whirlpool Refrigerators
Ice maker no longer making ice. A few weeks ago the water that was supposed to fill just the ice tray, didn't turn off, overflowed the ice tray and proceeded to fill the ice basket underneath. Since then...
Sounds like the water flowed enough to freeze the end of the fill tube shut. Best to prepare to replace the dual water control valve on the rear and near floor of refrigerator. If it was leaking and you should thaw the tube you need to turn the main supply of water off until replaced. Then thaw tube and replace the dual control valve. I will return with a part number providing your model number is correct, Thanks, Sea Breeze
Jan 17, 2010 | Maytag MBB1954G Bottom Freezer...
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
True TS-49 Refrigerator freezing food
NEWER T-49 s DO NOT HAVE ANY DEFROST HEATER OR TIMER OR CUTOFF'S All solutions involving repairs on these items are bogus. The defrost occurs when the compressor shuts down normally. During this time,since the fan never stops, it should circulate above freezing air around the coils and a slow defrost may occur. It is a poor system at best, and does not work well if the compressor runs a lot. MY erratic cooling was fixed by removing the copper sleeve and cold control probe from the evaporator(cold coil on top) Polish up the copper tube and the probe, reinsert and bend the copper sleeve very slightly so that it fits snuggly into the evaporator. Mine was very loose and not making good contact with the metal evaporator, giving erratic control of temperature.. Good Luck!!
Mar 16, 2008 | True T-49 Side by Side Refrigerator...
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
True T-49 Side by Side Refrigerator Commercial Logo
111 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
