Question about Nintendo Wii Console
Cannot connect my wii to my wireless internet
  • 864 Answers
I dont know if you need a guide on how to set it up or a trouble shooting guide. here is a trouble shooting guide and if you dont know what to do let me know and i will post a step by step guide on how to setup the wii on the internet. This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
Setting up wireless conection to my wii
  • 1Before you connect Nintendo Wii to wireless Internet, set up your Wii console according to the manufacturer's directions.
  • 2Turn on the Nintendo Wii and wait for the main menu to appear.
  • 3Using the Wii remote, point and click on the small Wii button in the bottom left corner.
  • 4Select Wii settings.
  • 5In the bottom right corner click the black square with the number 2 in it or use the right directional arrow to go to the next page. When you come to "Internet" click it.
  • 6To connect Wii to the Internet select "Connection Settings."
  • 7On the next screen select the first connection that says "none."
  • 8On the following page, when given the option for wired connection or wireless Internet, select "wireless."
  • 9Now it's time for your Wii to search for a wireless connection. To do this choose "search for an access point."
  • 10Press "okay" and find the name of your wireless Internet. If it's not on the first page, arrow down until you find it. If you need a password to access the Internet, you will be asked to enter it. Click okay.
  • 11Click save and okay so the Wii remembers the wireless Internet connection options for the future.
  • 12Finalize the Wii Internet connection process by testing the wireless connection.
  • 13When Wii's wireless Internet test finishes successfully, you're ready to play Wii online.
  • Read more: Video: How to Connect Wii to Wireless Internet ' eHow.com http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html#ixzz1f6AZS48m
    Nov 26, 2011 | NetGear WGR614 Wireless Router
    Tip
    How to connect your Nintendo Wii to the internet
    In this tips and tricks guide I will go over the steps you will need to take if you wish to connect your Nintendo Wii to the internet. If you want to connect wireless you will need to be within range of a wireless access point. If you wish to connect via a wired connection(Ethernet to modem or Ethernet to router) you will need a Wii LAN adapter which is sold separately.
    -Power on the console and press the A button to reach the Wii menu. At the menu, use your remote to select the Wii button at the bottom left.
    -Now select "Wii settings"
    -Now, hit the arrow on the right side of the screen to go to the next page and select "Internet"
    -Select "Connection 1: none"
    -Select "Wireless Connection" then select "Search for An Access Point"
    -Select "OK" then the Wii will display all the wireless access points(wireless routers) that are in range.
    -Select the wireless access point you wish to use.
    -If the access point requires a security key, you will need to enter this key in. This key is set when you first configure your wireless router.
    -Select "OK", then "Save Settings", and then "Yes".
    At this point your Wii will now test the internet connection.
    If you are using a Wired connection then you can connect the Wii directly to the router or modem and not use WiFi. Wii LAN Adapters are sold separately. If you have the LAN Adapter, follow the steps above up to the point were you select a connection type. You will select "Wired" instead of "Wireless. The Wii will now test your internet connection.
    I hope this guide has helped you connect your Wii to the internet. Enjoy!
    Regards,
    G33k
    on May 13, 2011 | Nintendo Wii Console
    Cant connect to my router netgear
  • Read more: Video: How to Connect Wii to Wireless Internet ' eHow.com http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html#ixzz1f6B48YnB
    How do i connect the internet to the wii???
    Here are step by step instructions on how to set up your internet connection. Please note, the Nintendo Wii connects to the internet via wireless signal, so you must have some type of wireless router or wireless internet connection to connect to!
    http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
    Sep 04, 2011 | Nintendo Wii Console
    How do I get Internet connection on my wii
    Here are step by step instructions on how to connect your Nintendo Wii to the internet. Please note that in order to connect to the internet on your Wii, you must have a wireless router or wireless internet connection, via that's the only way a Wii can access internet!
    How do u get internet on your wii
    Here are step by step instructions on how to connect your Nintendo Wii to the internet. Please note you will need access to a wireless internet connection, or must have a wireless router in order to connect your Wii to the internet. The Wii only connects via wireless signal!
    How do you set up Internet on the wii?
    To access the internet with your wii console you'll need either a wireless router/gateway, or a wii wired LAN connector.
    1. Power on your Wii console
    2. Access the "Wii Setting" menu by selecting the circular wii icon in the bottom left of the screen and then choosing wii settings.
    3. Use the arrow on the right of the screen to move to page two, then select "internet".
    4. Select "Connection 1 ' None"
    5. Choose "Wireless Connection" (assuming you have a wireless router), then select "Search for Access Point".
    6. Wait for your wii to scan, then select your wireless network, and if prompted enter your wireless network password/key. Then click "OK".
    You should now be able to connect to the internet. If your Wii runs a connection test and it proves unsuccessful it will display an error code. If you get Error Code 51330 or 52130 this means the password you entered does not match the password on the wireless network you are attempting to join. A list of all other error codes and what they mean can be found here: http://www.nintendo.com/consumer/systems/wii/en_na/onlineErrorCodes.jsp
    Jul 24, 2011 | Nintendo Wii Console
    How to get internet in our nintendo
    Their our 2 options to connect your Wii to the internet.
    The first option is wireless.
    1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
    2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
    3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
    4. Select "Connection 1: None"
        (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
    5. Click on "Wireless Connection" and then "Search for an Access Point."
        (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
    6. Select "OK" and the Wii will display all the wireless networks it finds.
    7. Select the wireless network that is yours.
        (If you're not sure which is yours, or you don't see any wireless networks, click here.)
    8. Select "OK," "Save Settings," and then "Yes."
    The second option is wired internet. For this you must purchase the Wii wired LAN adapter.
    Mar 01, 2011 | Nintendo Wii Console
    INTERNET CONNECTION
    To connect the Wii to the Internet you will need a wireless router in your home. Otherwise, you have to buy Wii lan adapter to connect it with an ethernet cable.
    To connect, go to Wii settings, then Internet, then Connection settings, then Connection 1.
    Then click wireless connection and then let the Wii search for a wireless access point (a wireless router).
    When your router appears on the list select it.
    If your router has a key, then you have to enter it.
    Press OK and you are finished.
    Jan 30, 2010 | Computers & Internet
    Connecting my wii to the internet
    to connect your wii to the internet connect to the following link or read the following instructions
    http://systemsetup.nintendo.com.au/Connecting_Online
    to connect your wii to the internet you will need to provide a wireless internet access point for it to find. you will need:
    a computer connected to broadband internet
    a wireless router OR Nintendo Wi-Fi USB Connector OR Wii LAN Adapter
    your wii console to be nearby all of the above
    If you are using the LAN Adapter you must plug the USB connection into the back of your wii console and the other end to your internet modems ethernet port. (follow steps below)
    if you are using a wireless connection follow steps below.
    Turn on your wii and on the main menu select 'wii' in the bottom left hand corner
    On the next screen, select 'wii settings'
    In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the 'Internet' button.
    Select 'connection settings'
    select an open connection indicated by 'none'
    select the corresponding option, Wired or Wireless connection
    Wired:
    Wireless:
    Select the corresponding option, Search for an access point or Nintendo Wi-Fi USB Connector
    the wii will search for an access point, select the access point you wish to connect to, and save the settings
    The wii will now do a test connection and do a system update, the wii will now use that connection point to acces the online services
    hope i helped!!
    Sep 19, 2008 | Video Game Consoles & Games
    Nintendo Wii Console Logo
    47 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
