Question about Medline Digital Blood Pressure Units ()
My medline bp monitor md2001 seems to have stopped working. The readout shows as ER 3. The cuff will not inflate. The batteries are good. Tried unplugging airtube and reinserting it. I can hear the hiss of air coming out of somewhere very near to the exhaust port. Before this, It would go up to about 150 systolic, then drop 20 or thirty points, then go back up to a similar high range, then stop and give an error message.
  • Lester Dore Aug 25, 2010
    I will contact Medline. I understand why you can't tell me how to repair it myself. BTW I tested the batteries and they were fine.
  • 3,866 Answers
Ok genrally a error 3 code means the batteires are low or the air pump inside is gone. Now we do not recommend you fixing the pump yourself per our Terms of service we cannot show you how to repair medical devices. As a Medical Asstant IO have experienced when these die this message was indicating its time for a new unit. Now do not shoot the messenger here it might be your battery not powering the unit correctly. Do not attempt repairs you will get bad results. You can call medline and have the replace the unit for you. let me know i am here to assit
please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 24, 2010
  • Grand Canyon Tech
    Grand Canyon Tech Aug 24, 2010
    you can contact med line HERE
    they have a lifetime guarantee on most of there products.
What does Er 4 mean on my cvs blood pressure machine
YOU did NOT SPECIFY your MODEL NUMBER but tonight ~ Christmas Eve ~ YOU got LUCKY! I found this and it may help you... but
THIS INFORMATION MAY NOT BE FOR YOUR DEVICE!
"LCD shows "Er 4"
Pneumatic system leak
or cuff is too loose during inflation
And this:
LCD shows "Er 0"
Pressure system is instable before measurement
Be still and measure again
LCD shows "Er 1"
Systolic pressure detect fail
LCD shows Er2 Diastolic pressure detect fail
LCD shows "Er 3"
Pneumatic system is
blocked or cuff is too
tight during inflation
Place the cuff correctly
and try again
LCD shows "Er 4"
or cuff is too loose du-
ring inflation
LCD shows "Er 5"
Inflation
above
300mmHg
Measure again after 5
minutes. If the moni-
tor is still abnormal,
please contact the
local distributor / ma-
nufacturer.
LCD shows "Er 6"
Over 3 minutes while
pressure above 15
mmHg
LCD shows "Er7"
EEPROM accessing er-
ror
LCD twinkling
Device
parameter
check error
LCD shows "Er 9"
MCU self-verity error
LCD shows "Er A"
Span error
LCD shows "Er b"
EEPROM Backup-error
http://webcache.googleusercontent.com/search?q=cache:V0KPe0jswmgJ:www.hmm.info/uploads/tx_sbdownloader/smartLAB_profi_user_manual_ENGLISCH_R4.pdf+&cd=2&hl=en&ct=clnk&gl=us&client=firefox-b-1
Dec 21, 2017 | Health & Beauty
Cuff doesn't inflate lifesource ua767 bp monitor. How do I reset or fix this? Have brand new batteries.
Inflating a Blood Pressure Cuff - YouTube
? 1:01
www.youtube.com/watch?v=8e6qtnHa8ps
Sep 30, 2008 - Uploaded by expertvillage When you take a blood pressure reading it is important to inflatethe blood pressure cuff until you no longer ...
Sep 24, 2015 | Lifesource Health & Beauty
How to calibrate omega 1445 bp monitor
My first question is how do you know it's not accurate? I would tee in a digital manometer (measure in mmHg), wrap the cuff around a glass bottle and let the cuff inflate. When it fully inflates the cuff...look at the readings between the monitor and your manometer. If they are within a few digits of one another, I would leave it alone.
Inaccuracies with patient nibp readings are usually related to improper cuff placement on the patient. There's usually a mark on the cuff to indicate where the cuff should be placed in relation to the brachial artery. I believe this unit utilizes oscillatory technology to determine readings and an improperly placed cuff can create inaccurate readings.
May 23, 2014 | Criticare omega 1445 BP Monitor
Good Afternoon, Regarding your Medline Certified Sphygmomanometers, Aneriod, and your model Accurcare MDS9400, can you tell me what the recommended PM schedule would be for this device? Thank you.
You'll need to get that information directly from Medline, the manufacturer.
If you live in the US call 800-633-5463
In Canada call 800-396-6996
In Mexico call 01-800-0898
Mar 17, 2011 | Medline Industries Medline Manual Digital...
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
What does it mean when you get a reading then 3 consecutive readings say EE
What is the pattern of the EE? If the two E's are on the same line, then you didn't inflate the cuff to a sufficient pressure. (Wait 2-3 minutes before trying again and then inflate the cuff to 40 mmHg higher than the previous attempt.)
If the Es are arranged vertically, then you overinflated the cuff. Any [ressure above 300 mmHg is beyond the range that this bp monitor can handle. If you reached this point by getting several underinflation alerts, ask your medical professional to test your bp and recommend the starting inflation level that you need.
Make sure that you have the cuff on properly. You may need to consider a different bp pressure cuff size to get an accurate reading.
I hope this.
Sep 09, 2010 | Omron Model HEM 432C Manual Inflation...
The Sunbeam blood pressure kit doesn't inflate the cuff.
You have the same problem I do. The hose socket to the machine is broken.
Jul 10, 2010 | Sunbeam Digital Blood Pressure Monitor
WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
Sphygmomanometer
most likely when you dropped it on the concrete floor the compact of it hitting the floor has either jarred something on the inside of it and has caused it to not work properly or find the papers to the machine and restart the directions for it. i hope that something i have said may work, good luck!
Jan 07, 2009 | Medline Industries Medline Manual Digital...
Medline Digital Blood Pressure Units () Logo
165 people viewed this question
Top Medline Health & Beauty Experts
rugby prop
ka4iup
ka4iup
wcdoc1953
wcdoc1953
Are you a Medline Health and Beauty Expert? Answer questions, earn points and help others
