Television picture has green tinge to it, and the channel numbers which are normally green are now blue - please can you tell me what the problem is?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Since no model number is given, I will have to say you need brand new cables. If your projector is an lcd model, your lcd panels could be going bad or your main board.
Posted on Aug 23, 2010
Is there a way to "fix" or adjust registration problem?The red is shifted low and blue is shifted to the left.
Yes! Most rear projector sets have a utility to align the red, green and blue colors.
You didn't include the make & model number of your TV set, but if you look at the menu section of your set, you should be able to find this setting - it may be hidden in an "advanced" submenu. Make sure you take the time to do all three colors. The more finicky you are with removing red, blue and green tinges - the better your picture will look.
Sep 30, 2013 | Televison & Video
My 47 in. Samsung flat screen hd tv has a picture but its a little dark then goes in and out of blue to green to red. It gets a good picture though. And the channel numbers blend together when I flip the...
Hello, I'm sorry to yell you that the lcd display (screen) is bad. Usually one side looks close to normal, and the other is dark and the picture drags and looks smeared. The cost to replace the lcd display is more than you can buy another set for, sorry. thanks, Terry
Oct 13, 2012 | Televison & Video
Sony television,model number KP51HW40,serial number 9026465,the problem is turn on the tv within in 30second the screen come to blue but sound is coming,no picture
If you are saying it goes to a bright blue screen I can tell you what to try.
This model has a history of bad picture tubes--red,green and mostly blue.
The blue screen can be turned down and I can tell you how.
The way you will know if this is your problem is take the set to a unused video input--all you should see is video 1 etc in green; if you see blue with or without trace lines you have the problem.
Let me know what you find and if so I will tell you how to adjust the set manually to try to correct it.
SD TECH
Aug 17, 2010 | Sony KP-51HW40 51" Rear Projection...
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
Mitsubishi 50 real projection blue screen
Turners are Bad Signal Board Call Encompass Parts 1-800-638-3328 or your nearest Repair Shop.
Dec 31, 2009 | Televison & Video
My KDF-60WF655 has a green tinge to picture
Sony extended the warranty on there optical blocks because of problems like this, unfortunately the extension ended in Dec. '08. With some digging you could find more info on this but I don't think Sony will help any more. You could however try having your optical block rebuilt instead of buying a new one, should save you hundreds. Good luck!
Jun 22, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Pictures have a green shadow on all images
Remove front grill and chip board ,there are three knobs one is for brightness I think another for a sharper picture (best to use while convergance adjustment and the third which should balance your
black or white screen to have blue,red, or green tinge ,you like to have it as neutraul as possable.
if you are stll getting everything in blue,green or b-52 agua marine ,your red lamp may be burnt out!.
Feb 05, 2009 | JVC AV-48WP74 48" Rear Projection...
The picture is only producing the basic colours red green and blue
You can start with the make, model and age off the back of
the TV..........................T.
Dec 24, 2007 | Televison & Video
Too much yellow in picture
The problem with the set is that the blue gun has gone weak, and not emitting at par with red and green guns in your picture tube. Turn of the blue screen and get the grainy display on the screen (detach the cable) and enter into service mode to fine tune until you get a perfect or black and white grain pattern.
Dec 19, 2007 | JVC AV-27230 27" TV
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
94 people viewed this question
jasbo
jasbo
