Question about Garden
Im trying to put back the carburator but the trotle cabble want fit whit the carburator in place
    President:
  • 1,545 Answers
Remove the carb, put the end of the throttle cable thru the end of the butterfly valve shaft where you have room. Hold it in place THERE while you put the 2 bolts back thru the carb. Don't forget any carb adaptor/spacers and gaskets.
Posted on Aug 23, 2010
Problem with a tiller Earthquake viper engine either the carburator or carburator gaskets LBLSNMC43
The Viper Engine is a Honda clone. Try a new carb for $15 0n ebay. http://www.ebay.com/itm/NEW-GX160-5-5HP-HONDA-ADJUSTABLE-CARBURETOR-WITH-FREE-GASKETS/121225345625?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D30002%26meid%3Df495007fc18649159ceb1009031e4fad%26pid%3D100011%26rk%3D2%26rkt%3D10%26mehot%3Dpp%26sd%3D261393057447
Mar 04, 2013 | Ardisam Inc Earthquake Mini Cultivator
I have a mitsubishi lancer 2006 1.6 liter.. the rpm is low and sometimes the engine turns off.. why?
@Cyril.. Try to adjust your cable wire in your trotle then set it up @ 900 rpm.. Well that what i did to my 2004 lancer oz.2.0L it works
Feb 15, 2013 | 2006 Mitsubishi Lancer
Otmail.com Buble thing at carburator has stuck in and will not come back out any advice
I believe that your question is in reference to the primer button on your carburator. If this is so and your button is pushed in then you will have to change the button. Take a pair of needlenose pliers and pull out the damaged primer bulb. Then go in with a pick tool and pull out the ring that is seated in the carburator at the bottom of the primer bulb. With the old primer bulb out of the carburator you can now install the new primer bulb. Put new primer bulb into place and with a dull punch slowly and very carefully seat the new primer bulb. This should put you back in business again. GOOD LUCK.
Jul 05, 2011 | Briggs & Stratton Garden
My carburator is not properly working. i want to have a professional assistance
there is not carburator on that car is call trotle body ...........what is the sintome on the car black smog the car shake or what
Dec 18, 2010 | 1996 Nissan Sentra
Hello! trying to clean the carburator I took the head of. after I screwed it back I started the bike and it went crazy! the engine imediatelly accelerated like if was pulling the accelerator handle to the...
im pretty sure that you did not place the place the piston to its original place.
try to check the piston. make sure that it is put correctly..
im sure that it is the thing that you made wrong
Dec 07, 2010 | 2000 kawasaki KMX 125
SUZUKI RF 600 R, problem with idle speed and cold start, i cant control trotle at idle speed, at higher rpm the engine is working without problem but when i rellease the trotle engine is stop. What can i...
If the bike starts up and the idle speed creeps to high revs all on its' own, this indicates an air leak somewhere between the center throat of the carb and the cylinder head. This is normally a rubber seal or rubber manifold that is old, hard and cracked. I am sure the carbs need to be cleaned, remounted and adjusted. This is a nightmare for the novice mechanic. Replace all rubber fittings and seals including hose fittings and hoses.
Aug 13, 2010 | 1995 Suzuki RF 600 R
Hi i have a 06 accent that will start and tick over but when you go to take off it looses power and chucks and cuts out and might take a half hour befor it will start up again , no engine warning light and...
Check the fuel pressure, fuel pump (which is inside the fuel tank), fuel pressure solenoid (if fitted) and fuel pressure regulator (if fitted). Check and replace the fuel filter and check the injector flow rates in case you have clogged or faulty injectors.. I would lean towards a fuel supply issue here so look at the fuel filter and fuel pump first..
Jan 14, 2010 | 2006 Hyundai Accent
My 2002 ford taurus's gas pedal it get's stuck and it revs then the rpm goes down it goes
It is very rear for the pedal to get stuck it is most likely the acselaretor cable is geting stuck du to:
1 Gunk at the trotle body , clean with carburator cliner.
2 Acselaretor cable path has changed by some one and it is getimg stuck . coreckt the path
Nov 29, 2009 | 2002 Ford Taurus
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 08, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need help reconnecting fuel lines
One fuel line (the on with the filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The other hose comes out of the tank and goes to the bottom fitting on the primer bulb. A third section of fuel line goes from the top fitting on the primer bulb to the top fitting on the carburator. Hope this helped and best wishes.
Sep 01, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
