Question about LG 42LC2D 42 in. LCD HDTV
My LG TV has gone crazy. The Volume goes up by itself and when it's off it turns itself on as though it has a mind of its own. Any suggestions? Is it worth trying to fix? Any idea what it would cost?
SOURCE: LG tv turns on by itself
this problem is with the inner small micro-swtches ,the side buttons inside are getting intermittantely short...changing of those switches will solve the prob. tc--
Posted on Oct 28, 2007
  • 100 Answers
SOURCE: LG 42px5d the volume goes up and down by itself.
hello, it look like the volume and channels micro swichs at the front of thr tv.
are broken, you should change all off them
Posted on Feb 07, 2011
  • 3 Answers
SOURCE: LG plasma tv made loud popping noise
The plasma gas tubes may be damaged or the gas couldve leak out. remember plasma have to remain upright at all times even when transporting them, if they are not you should just set it up straight for about 3-4 hours before turning it on.
Posted on Apr 23, 2009
msbigdog7
  • 332 Answers
SOURCE: the volume and picture on my LG 42LB1DR TV shuts off by itself
check the menu for power saving option if it`s on shut it off.
Posted on Aug 28, 2009
  • 1294 Answers
SOURCE: my LG tv started turning
Please descativated the on timer or off timer selection.
Posted on Sep 07, 2009
LG 55LE5400 tv
It's a power problem , not sure of the model . The TV shuts itself down to save itself . It goes through a series of self checks before power up and if those aren't made it shuts down. If you are unsure of how and why I would suggest you take it to a pro
Jul 02, 2015 | LG Televison & Video
Volume goes max and will not lower.
Hello
Please remove the batteries from the remote and check whether it is possible to use the local keypad on the TV? If the volume increases, it may be a problem in the local keyboard.
Apr 02, 2014 | Samsung LN32B550 32 in. LCD HDTV
Remote sends tv crazy
The volume controller may have been damaged from a power surge or internal disturbance; not related to the a remote control. Your TV has a set of External Out connections, usually RCA jacks colored RED White and/or Black. Red and White jacks are relative to Right and Left Speakers when an attached cord with RCA male connectors are used and connected to an Amp or some type of receiver. You should be able to use the TV OUT Audio to a small Amplifier and connect to a set of inexpensive speakers or any external speaker set. This method bypasses the TV's Internal speaker system as an alternative measure.
Dec 23, 2013 | LG 42" 5700 Series LED HDTV - 42LN5700
LG 42LC7D-UB after few minutes the sound goes off and channel change by itself
When heats up, the supply voltage from the main power supply board goes less. Check all the soldering to this board for any loose solder terminals. Resolder all the suspected solder terminals by applying a little more solder. If it do not help you, replace the board as card basis.
Jan 09, 2013 | LG 42LC7D-UB Television
Lg kf750 screen displays lg at start up but then
Yo man.. I just had the same ******* problem. Drove me crazy cause the phone still worked but I couldn't see what i was doing haha. But hey, i solved it!
Hold down the middle button+the call button+the C button for a while and the screen will turn itself on again!!!
Hopefully, you haven't gone to an expensive phone-repair-place yet.. Godd luck!/Anni
Sep 07, 2009 | LG Secret ? KF750 Cellular Phone
The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
May 10, 2009 | Sansui HDLCD3210 32 in. LCD TV
LG LCD 32 INCH acts crazy
ur tv problem is from the ad(analog to digital) or main board which host the rom that holds the manufactural programs.this rom program could only be alter by the manufacturer or an authurise personel. u can order for new ad board.
Nov 09, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
RCA big screen has gone crazy!
Sounds to me like you may have a cold solder joint in a board ( loose lead on the pc board ) or you might have a b ad eeprom causing the problem. You may need to replace the main board. Also another sitution I have come across is a stuck button on the tuning strip board ( the board/switches that change channels, volume etc ) on the tv. maybe also since the remote sensor is light senative, it may be in the line of the sun ( cover the ir senor on the front of the tv to illaminate that problem ). Good Luck and if you the suggestions don't correct the problem. email me at wyoed1@aol.com or continue with this at this address. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | RCA P52939 52" Rear Projection Television
Picture going in and out
What is the make and model number? The symptom you are describing is very common on Mitsubishi projection sets, but since you did not say what kind of TV you have, I cannot tell you what is wrong yet.
Sep 14, 2007 | Televison & Video
LG 42LC2D 42 in. LCD HDTV Logo
549 people viewed this question
Computer Repairing
Computer Repairing
