Question about Ebel Classic Wave 9090F249725 Wrist Watch
Ladies Ebel wave w/diamonds and sapphire face............jeweler cannot replace battery, does crystal need to be removed or remove back?
  • 831 Answers
The back will need to be romoved, but in doing so yourself, you will VOID your warranty, and since this is an expensive watch, I highly recommend that you send it in.
You can find all this information here:
http://service.movadogroup.com/faq.cfm#127
Best regards.
Posted on Aug 23, 2010
Ebel 1911
kori, I think your watch needs cleaning. Take it to a good repairman/jeweller. These are hard to find watches and you must keep it.
Jan 23, 2014 | Ebel 1911 Watches
I have a ladies wave, two tone, dia dial. Can I buy a diamond bezel for this. Where and how much would it cost.
I can pull out the crown 1 step to adjust the date and another step to adjust the time but not completely. I looks also like e screw but is that really the case? Do I have to use a lot of force to get the crown out?
Jan
Oct 14, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
How to remove stem to get to battery in ebel ladies watch?
On my men's classic wave, the stem is removed simply by pulling it out. It feels like it's requiring a lot of force, but it is designed to have resistance so that it's not pulled out accidentally when setting the time.
So to change the battery, you remove the 5 faceplate screws, remove the crystal and gasket, pull out the stem and then the whole face/movement assembly will pull forward.
NOT positive yours is the same, but that's how my men's Classic Wave is. Good luck!
Dec 18, 2010 | Ebel Classic 1157111/0225 Wrist Watch
The crystal is scratched, can I fix that myself?
Thanks for contacting FIxYa.
  • Use a jeweler's loupe to identify all scratches on the watch crystal. You do not have to remove the watch crystal from the watch.
  • Use a polishing cloth to remove dirt, grit, lint or any debris on the watch crystal. Squeeze a small amount of standard toothpaste with abrasive properties onto the watch crystal. Gently brush the toothpaste into the crystal for five minutes. Wipe clean the watch crystal. and repeat another five minutes.
  • Use the jeweler's loupe to inspect your progress. Repeat application if necessary. Apply Brasso polish once the watch crystal is wiped clean. This will polish the crystal to a clear, bright shine.
  • Apply Autosol or Polywatch to the watch crystal in the same manner as toothpaste if you prefer to use a product specifically designed for watch crystals. These products will provide the same results as toothpaste. You may also apply Cerium Oxide, a glass scratch remover used specifically in the window manufacturing industry.
  • Apply a small amount of 3-micron diamond paste using your finger or a Kleenex if removing scratches from a sapphire crystal. Rub the paste in for about five minutes. Remove paste with cloth. Buff the sapphire crystal with one-quarter micron buffing diamond paste for finishing.
  • Use a toothpick to remove excess polish and gunk that may accumulate between the crystal and the bezel that secures the crystal in place. Gently work the toothpick around the diameter of the bezel. Wipe the bezel clean with a cloth.
  • Buff the watch crystal with a polishing cloth.
  • OR..take to a local jeweler/watchmaker.
    Best regards. Jewel
    Sep 10, 2010 | Relic Watches
    I have a ladies Philip Stein, w, double movement. Tried to buff crystal. Now neither movement is working. Batteries are OK
    If the stems are in the time positon and the batteries are ok what probably happened is extreme heat. You tried to polish a mineral crystal and it got hot. The only type of crystal you can polish is acrylic. Most of these models come with mineral crystal or scratch proof sapphire crystal. I recommend going to a watch maker/technician and having the movements replaced. A reputable watch maker/technician will be pretty reasonable.
    Sep 19, 2009 | Philip Stein Teslar Small Case Diamond...
    Ebel Wave lady's watch battery
    to change the batt on an ebel womans watch i simple. 1 take out screws from bezel. 2 lift off , make sure to keep rubber gasket in place. 3 pull out stem to the set position. 4 be very carefull not to bend / touch hands. 5 turn case upside down, and you will see the opp side from the winder drop out slitely. with your fingernail pull downwards gently on works, then when you have it out a little on that side, turn it back over. and continue to lifft up gently, 5 as you do so, start to rowtate the works counter clockwise. the stem is made to .bend / swivel and the works will turn upside down and lay back into the case. to protect the face while installing the batt. 6 when done gently lift the same way but rowtate clockwise. but make sure you grab sides of works and not the face. ( the hands are very delicate) 7 take the batt to a jeweler to replace you will never find a batt with the same number ( ebel made sure of that ) they want you to pay 140.00 to 240.00 for them to do it. but a jeweler can match it. now that said, once you take the bezel off, your ebel warenty is void. so 140 -240 or $5.00 your choice i have had meny watches over the years all with rubber gaskets and have replaced batts is some five times and the gasket are still fine. and a batt will last 3 to four years. five in 15 years could cost you $ 1020.00 in the long run. hope that answers your question.
    Feb 19, 2009 | Ebel Classic Wave 9090F249725 Wrist Watch
    Ladies Classic Wave Diamond dial
    Yes, you can. Contact your nearest Ebel retailer and they will advice you.
    Bear in mind- this is a costly upgrade.
    Jul 19, 2008 | Ebel Classic Wave 9090F249725 Wrist Watch
    Ebel Classic Wave fitting a new crown
    i have changed the battery on my and my wifes ebel classic wave watch,,
    step 1 ...remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
    step 2 ...remove all 5 gold bezel screws
    step 3... be careful,, the bezel/crystal will pry off easy
    step 4... be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
    step 5.. small screwdriver and remove/replace battery
    step 6... reinstall watch guts/bezel and gold screws
    step 7... push crown back into watch
    step 8... take wife and kids to dinner ,,you just saved three hunderd bucks
    if have done it many times ,, you can do it !!!!
    Dec 10, 2006 | Ebel Classic Wave 9090F249725 Wrist Watch
    Ebel Classic Wave 9090F249725 Wrist Watch Logo
    240 people viewed this question
    Top Ebel Watches Experts
    Coss
    Jimmy Accardi
    Tom Chichester
    Are you an Ebel Watch Expert? Answer questions, earn points and help others
