Question about Mitsubishi VS-60607 TV
Very dark picture and lines in the tv. if you leave it on for a real long time then it starts to work a little better
    Master:
  • 742 Answers
Sounds almost like a high voltage drive problem.
Posted on Aug 23, 2010
Haier LCD picture goes dark, sound only
hi, since your TV is under warranty,It is better to ask for a replacement a new one ..the problem is factory defect.
Apr 02, 2012 | Haier HL15R LCD TV
How to change resolution on a Toshiba LCD TV from 480i to better?
Can't solve this problem, because I have the same one! I can say that adjusting some of the fine picture contrrols, like brightness, contrast, color etc help a little. This TV is supposed to go 720 and as high as 1080 I thought?..........
Mar 02, 2010 | Toshiba 32HL67 32 in. LCD Television
JVC TV THE PICTURE IS DARK EVERYTHING ELSE WORKS GREAT
there so many things which can cause that to happen an these are thwe following,
i a tube has to be tested
ii a line transformer
iii vedio amplifier
this tests can be done in w/shop where other tvs are of the same.
Mar 27, 2009 | Televison & Video
Screen is too dark
with a flashlight at the back of the set often times there is an adjustment you can make WITHOUT having to open the set!!!
look for a little hole in the back of the plastic cabinet labeled SCREEN then with a flat screwdriver holding only the plastic handle, insert it into the hole and SLOWLY rotate until the screen brightens up until it is watchable.
This is compensating for age in the picture tube. you may get a few day or a few more years! of a much better picture.
If you start seeing some thin lines on the screen then back off you have gone too far. Do this adjustment with the brightness and contrast controls on the menu turned up all the way.
it is also safe to play with the focus adjustment right next to the screen if thing seem a little blurry. you will need two people one to watch from a distance for best picture.
Feb 10, 2009 | GE 31GT660 TV
My tv picture has gone dark
How old is the TV and did you ever have it calibrated?
Nov 20, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mar 06, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi rear projection tv white screen goes dark and....
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0157" use the audio button to select "video chroma" adjustments, use the video button to select item "68 - AG1", use the adjust button to change the setting to 0, then press the enter button to store the change
Mar 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Picture Darker When Changing Channels Sony KP-57WV700
I've had the arcing horizontal lines from time to time in all three colors (differing occasions). I dunno the correct lingo for this stuff, but having the same TV and fixing it myself here goes. It helps to have another set of hands while doing this. Also, eventually you will need to work in the dark so have a small flashlight handy. Put your tv on an unused input so you always have a "dark" background.
Open up the front panel of the TV.... There are phillips head screws running down both sides around the back side of the panel. After removing the screws and the little side panels they screw into, the whole bottom half of the TV can be popped off. Be careful not to pull it off to far as there is wiring running to the front panel controls. (you can disconnect the wiring plugs if you need the panel out of your way, just remember where and which way they go.) Behind the main silver panel is a smaller panel made of a thin pressboard type material. Remove this panel as well. Inside this second panel you will find 3 little knoblike controls (that also have a screwdriver head) that control the "color drive" of the corrosponding guns. They have a little strip of locktite on them to keep them from moving but it dosent hold on to hard. I'm telling you all this from memory and I'm sure the real techs out there head's are about to explode due to my cavalier attitude toward all this. I wish I could tell you exactly which one is the blue but i've adjusted them all at one time of another and can't remember which one is which.
Pick your favorite knob and SLOWLY adjust it to the right. Just a little bit....too much and your TV will pop off and you'll think you've blown up your tv. (I did this once, and had to uplug the tv and let it sit for a little bit before it came back to life, I probably got real lucky on that one)
Now...as you SLOWLY turn this knob, one of two things will happen. one.....another color arc is going to appear on your tv...this tells you you've got the wrong knob. turn it back to where it was. two....your blue arcs will brighten... thats the one you want. Kill the lights in the room...the darker the room the better. Turn the knob down (to the left) until the point at which the arcs disappear, if you go too far, that color will be "underdriven" so you want to hit it just right. It helps to have someone at the back of the room to better observe the arcs, it can be hard to do this sitting as close as you have to be to adjust the magic knobs.
Repeat if you have any green or red arcs.
Use some locktite on the knobs when you have them where you want them, i've used nail polish if I didn't have locktite available.
Rebuild your tv.
Dec 28, 2007 | Sony KP-57WV700 57" Rear Projection HDTV
Dark picture
Disconnect the game and revert back to your old hookup. Better now?...accordianman
Dec 26, 2007 | GE 32GT740 32" TV
Mitsubishi VS-60607 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
