Question about Bosch WAS24460UC Front Load Washer
There are three compartments to put detergents ect. It seems like the liquid detergent should go in the one marked II because that is the one that water runs through as soon as you turn the washer on and it has a blue plastic thing in the back of that compartment but someone told me that the manual (that i don't have because my installer took it) says to put the liquid detergent in the compartment marked I...what is correct?
    Top Expert:
  • Bosch Master
  • 36,514 Answers
Try Googling (bosch)(WAS24460UC)(manual) without parens to get instructions.
Posted on Jul 11, 2017
  • 236 Answers
SOURCE: Bosch Classixx 1000 manual
usually it is the larger for the main powder the second largest for the prewash powder and the smallest (labelled with a "max line" for the fab conditioner) the calgon can go in with the main wash or be put straight in the drum.
Posted on Jun 02, 2007
  • 27 Answers
SOURCE: detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Posted on Jun 26, 2007
SOURCE: detergent
the detergent goes in the right, dry stuff (flakes) in the middle and any second stage product in the left
Posted on Dec 04, 2007
  • 1294 Answers
SOURCE: Cleaning agent placement
From left to right as you see.
1 This is for your frontloader soap powder or other detergent.
2 Fabric conditioner or softener. If this is too thick, mix with water to prevent clogging.
3 Detergent for soaking agent. I dont see 'bleach' anywhere
There is an panel, front bottom right which holds your pump filter, unscrew to clean out. But wait. Plug off the mains.
You will see a hose on the left, this is if your water in the tub cannot drain, you can drain it here. Your tub can hold upto 20 litres/4.4 gals.so have a suitable container to collect; carefully remove cap to drain out. Reason why it doesn't drain is because there is a block in your pump (right side) which you must clear.
To keep your pump from probs (a tip which you seldom see) empty all pockets of clothes before putting into machine. I have a non electronic Philco which i dont remember cleaning with hotwash or anything, 10years +
For exteriors do not use solvents or steel wool. Only hot soapy water with a mild non-abrasive cleaning agent, dry with soft towel.
Above should be useful. Pl rate.............
Posted on Mar 23, 2009
keithd2704
  • 56 Answers
SOURCE: The Softener is not going through.
Hey Ben Fixit,
Depending on what unit of Nexxt 500, not all of them have a slide out soap box. The unit I have of the Nexxt 500 series only has an access lid that lifts up.
To address the blockage on this style of machine, a user can start with a kettle of boiling water and slowly pour the water into the fabric softener well.
Remember fabric softener is made with plant fats and during the colder months can coagulate and clog the lines. This is due to the colder temperature of the water, especially if the user does not use hot water to wash all of their clothes.
Keith
Posted on May 31, 2010
Fabric Softener Does Not Drain
compartment 1: Detergent for pre-wash
(powder)
Before pouring in the detergent, make sure that extra compartment 4 has been removed.
compartment 2: Detergent for the wash cycle
(powder or liquid)
Liquid detergent should only be poured in immediately prior to the wash cycle start.
compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow from the grid.
extra compartment 4: Bleach
! Do not use Hand Wash Detergent because it may form too much foam.
Cleaning the detergent dispenser
Remove the dispenser by raising it and pulling it out (see figure).
Wash it under running water; this operation should be repeated
frequently.
25569074-ineink0kisfnom0atbkujjcx-3-1.jpg 25569074-ineink0kisfnom0atbkujjcx-3-3.jpg 25569074-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Mar 14, 2015 | Ariston Technologies AW125NA 13 lbs. Load...
Whirlpool commercial duty washer - liquid detergent
Jenny what do you mean by 'flow right out of the compartment'. IF the detergent flows right into the machine as you pour, it ok.
Jan 05, 2014 | Washing Machines
I have a front loading Kenmore washer and when i put liquid detergent and fabric softener, the liquid flows into the machine - should the detergent and fabric softerner remain in their compartements until...
Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Jul 26, 2011 | Kenmore Washing Machines
Which slot do you put liquid detergent in?
If it is fabric conditioner, then use the smallest compartment, if washer detergent, then use the largest compartment.
Aug 14, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I accidentally put liquid detergent into the rinse compartment.
Wipe down the rinse compartment, fill it with tap water and run as many empty cycles as it takes to flush out the improper additive.
If you put Dawn or Joy type detergent rather than machine detergent it may take awhile but it works once the unwanted chemical is flushed out completley.
Don't work to hard, let the machine do the work for you.
Dec 28, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Do I put powder detergent in the same place I put Liquid detergent?
Detergent compartment
Add liquid or powdered detergent to this compartment for your
wash cycle. The detergent separator must always be in place,
either in the front or back position.
 Do not fill beyond the “MAX” level.
 Liquid or powdered color-safe bleach may be added to the
Main Wash compartment along with the same type of
detergent, liquid or powdered.
 Liquid detergent: Put the SEPARATOR in the front position,
between the guides, as shown as shown by Position 1 below.
There will be no gap between the bottom of the wash cycle detergent
compartment and the bottom of the separator.
Powdered detergent:
Put the SEPARATOR in the back
position, behind the guides as shown by Position 1 below. There will be
a gap between the bottom of the wash cycle detergent
NOTE: The separator will be in the POWDER (back) position
when shipped from the factory.
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG 2277 Liquid Detergent Box & Insert
please put detergent into the main(left) side of the dispenser
Feb 15, 2009 | LG WM-2277HW Front Load Washer
Detergent drawer
I ended up having to call Samsung support for this same question. Left to right two vertical bars = detergent (liquid or Powder) flower = softner, single vertical bar = bleach.
Oct 19, 2008 | GE Energy Star WCVH6260F Front Load Washer
How to use liquid detergent and powered bleach?
You should be using a HE liquid detergent. Does you machine have a dispenser for that? The detergent should go in that dispenser. You can put the powdered bleach right into the drum before you load the clothes. I am assuming this is an all fabric bleach.
Happy Clean Clothes!
Aug 18, 2008 | Kenmore Elite 45986 Front Load Washer
Completely dumb question
Hi, we have a hotpoint aquarius - the "fan" compartment on the left is for fabric conditioner, the blue thing is to save you measuring it out in the bottle cap. Number I is for prewash detergent (only if you're doing a prewash) and number II is the main detergent compartment, the one you would usually use. Hope this helps?
Jen
Jan 17, 2008 | Hotpoint Aquarius WD640 Front Load...
Bosch WAS24460UC Front Load Washer Logo
62 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
