Question about Canon X25 Toner Cartridge for imageCLASS MF5500 Copier
I have bought 2 OEM canon X 25 toner. They print came out blur and patches.
  • 1,219 Answers
do you mean that on the printed/copied picture the toner isnt "baked" and it smudges down?
If thats the case that means that you have fixing film problems and the cartridges are OK.
Hope that helps!
Posted on Aug 24, 2010
Blurred print of incoming and outgoing report
There are usually two things that can cause blurred printing.
1 The toner/drum needs changing.
2 The fuser assy is worn and not fusing the toner onto the paper correctly. This is easy to check. Does the print rub off the paper with your finger? If so then a new fuser is required. Also its possible a tooth on the gear that drives the fuser is broken. The fuser gear may have also worn down and its jumping on the gear that drives it.
Dec 20, 2013 | Canon LaserClass LC 8500 Plain Paper Fax
Cannon LBP 2900 lazer printer cartridge is refilled. than it prints blank page only.
canon 2900 printer first time refilling completed but print not coming wht is problem
Sep 12, 2012 | Canon LASER SHOT LBP-2900 Printer
My ir3300 paper blur
Hi . You need to make this test . Try to print a report again. But this time open the front door in the middle of printing so the paper will stop between the drum and the fixing unit . The porpoise of this is see if the information is blurred before entering the fixing unit. . Is the information is ok before entering the fixing unit . You need to replace the grease of the fixing heater . If the information is already blurred before entering the fixing unit you need to check the laser unit. Probably dirty mirrors inside that unit .
Jan 27, 2018 | Canon Office Equipment & Supplies
My prints are coming out blurred. Why?
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon PC 785 print out very light in middle of a page
Hello sir; The problem still on the cartridge, may be you bought one is GENERIC, not OEM, try another one.
Mar 30, 2009 | Canon PC-785 Copier
1 get 3 fuzzy lines on page
If you're getting frequent paper jams, it's usually caused by the feeder motor assembly failing. When the paper is pulled through the printer, if the assembly is failing, it causes the paper to jam and can effect how things are printed. (Sometimes it will go to fast and things will get blurred, sometimes it'll go to slow and text overlaps)
If that sounds like the problem, it's cheaper to replace the printer (can be bought for $50) the it is to repair it ($25 for the motor, $45 for labor to install the motor)
Aug 28, 2008 | Samsung ML 2010 Laser Printer
Canon ir5000
assuming it is a black patch of toner, the drum blade needs changing or the waste toner mechanism needs to be looked at
Aug 27, 2008 | Canon imageRUNNER 5000 Copier
Unisys UDS 25 Printer Problem - Identical to Lexmark T614
check the Technical Support Team for this machine My guess is the drum is on its way out - or some other replaceable control item but they will know.
May 25, 2007 | Lexmark Optra T614 Laser Printer
Canon X25 Toner Cartridge for imageCLASS MF5500 Copier Logo
80 people viewed this question
old marine
old marine
