Question about Bunn B10
My bunn is leaking? - Bunn B10
  • 189 Answers
Do you have the model and date code? If you will call customer service at 800-352-2866 we can help you with this issue.
Posted on Sep 13, 2010
Bad leaking bunn commerical VPR pour-omatic
You will need to replace it, parts are not made for repair except under warranty.
Nov 30, 2016 | Bunn Coffee Makers & Espresso Machines
Water leaking from my Bunn ThermoFresh
if it is under warranty contact bunn directly , if not throw it away . they are not fixable
Feb 12, 2014 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
My Bunn coffee maker leaks out of the bottom
If you will call Bunn Customer Service, there is a seal kit that can be sent out to fix the leaking problem you are experiencing.
Jun 01, 2010 | Bunn 10 Cup Home Coffee Brewer
Bunn code date 145000 water leak took apart need
If you will call customer service, a seal repair kit can be sent to you which is successful 90-95 percent of the time in fixing the leak problem.
Mar 25, 2010 | Bunn 10 Cup Home Coffee Brewer
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Jul 13, 2009 | Bunn 10 Cup Home Coffee Brewer
MY BUNN COFFEE MAKER LEAKES WATER
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Mar 16, 2009 | Wega Mininova EPU Espresso Machine
Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
Mar 06, 2009 | Bunn NHB Coffee Maker
Bunn (Pour Omatic) coffee maker has been leaking water - what would couse it to leak? Thank you
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
Oct 28, 2008 | Bunn NHB Coffee Maker
Bunn B10 Logo
41 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
