Question about HP LaserJet 3330 All-In-One Printer
The Scanner bulb warming up cycle is stuck and it keeps making the set-up sound. how do you stop it?
This worked for me today 8/29/10
A much easier way to clean the mirror.
Thanks to: http://www.statusq.org/archives/2008/01/21/1745/
Basically, you power off the printer and unscrew the screw which allows you to remove the small piece of glass to the left of the main scanning glass.
Using some needle-nosed pliers through the opening, grasp the drive belt and use it to move the scanning head across from the right hand side of the scanning area to the left, until it is right under the opening. At the bottom of the wide slot, there is a mirror, and it gets fogged up with something.
Shine a good light in there and use dry Q-tips to give the mirror a good clean. Then reassemble everything and turn the printer back on. After a little warm-up, you should get the Ready€™ prompt again, and your heart will be filled with joy.
The whole process should only take about 5 mins. There may be other things which cause a scanner error, but this fixed it for me and, it would appear, for many others.
Posted on Aug 30, 2010
I have an hp LaserJet 3300. I reads "Scanner Bulb Warming Up" in the window. It then begins to make a galloping noise. It will print from the computer but nothing else. The galloping sound...
Hey,
It sounds as the lamp is stuck, if you open the cover do you see the lap nudging alittle back and front?
This might be fixyable by opening up the cover and clearing the jam.
or if the bulb is faulty it would need to be replaced but in most cases, people just buy a new scanner / printer becouse the repair price goes around the price of a new printer.
Sep 04, 2008 | HP Office Equipment & Supplies
Scanner error message
is your printer is detected in the device manager settings??
Mar 05, 2008 | HP LaserJet 3030 All-In-One Printer
Do I need a new scanner bulb?
It sounds very much as if the scanner is faulty/failed. The warming-up phase is to ensure that the scanner lamps output is steady, making for consistent scans. Usually this is just a simple timing circuit.
Having once tried to fix a broken flatbed scanner myself, I found that obtaining the correct replacement lamp for it was impossible - I think inkjet printers and scanners are considered "consumable". You may be better off buying a new printer. Alternatively, if it keeps producing good prints, consider buying a separate scanner. HTH
May 27, 2014 | Canon PIXMA MP780 All-In-One InkJet...
Scanner bulb warming up keeps cycling, seems like the scanner is not working and can not print or copy. Sounds like the movement across the scanner doesn't happen.
Optical scanner assembly faulty, its avil replace it if not open the unit gently remove the cover clean reflecting mirroes with ears buds to aviod scratches, refix and try.. best of luck
Sep 08, 2011 | HP LaserJet 3330 All-In-One Printer
Hello, The scanner & photocopier were not working and the screen was just stuck on the "scanner bulb warming up". Then, after days of trouble shooting, it finally began making a noise,...
From what you described it sounds like you need to get the "scanner assembly" replaced.
The bulb is probably bad and won't come on to full power.
Not knowing what kind of printer you have, probably won't change the fix. If you can look at the event log you may be able to see an error code which could make it a definite scanner assembly replacement.
If you want to throw money at this unknown printer, get a tech to look at it and give you an estimate.
Jan 17, 2011 | Office Equipment & Supplies
Printer making rattling noise and then gets stuck at scanner bulb warming up
The "scanner bulb warming up" error is caused by dirty scanner optics. We have a step by step guide to the cleaning procedure posted on our web site at:
www.ccl-la.com Click on the printer repair link and then the HP page. You will find the guide there, it should not take over about 20 minutes to do. If you have any questions just contact me at the email below.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Over 21 years of PC and Printer support/repair
Dec 17, 2009 | HP LaserJet 3330 All-In-One Printer
the cables connected internally to the scanner unit had gone short some where in between you have to check it manually by opening the device .and then remove the cables and replace them with a same length cable.you can get the cables from any electronic shop who keeps printer assessories.
Sep 29, 2008 | HP LaserJet 3330 All-In-One Printer
Scanner light stays on
I have the same problem. I chatted with HP customer care for an hour but it can't be fixed. The only thing you can do now is set the power saver mode to 2 hours, so bulb will turn off in 2 hours. Only way to minimum power consume.
Mar 21, 2008 | HP LaserJet 3055 All-In-One Printer
Printer/scanner making a hunting sound will not function
The scanner assembly is bad. Even though it is big, it is not that difficult to replace. Google C9124-60103 for part
Jan 16, 2008 | HP LaserJet 3330MFP All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
648 people viewed this question
Seeker5211
Seeker5211
