Question about Fossil Metal Dress Silver Dial ES1053 Watch for Women
How do I open the battery cover to insert the batteries
  • 831 Answers
Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see.
  • 2Pull out the stem, which releases the back on some watches.
  • 3Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
  • 4Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  • 5Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  • 6When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
  • Posted on Aug 24, 2010
    Change battery in Elgin watch FQ024-007
    The back of this watch doesn't pry off, it screws off.
    I used the open tip of a needle-nose pliers to unscrew the back of the watch by inserting the the tips into opposing grooves in the back of the watch and turning it counter-clockwise.
    Once the back of the watch is off, there are a few slotted screws that appear to hold a metal cover over the back of the watch 'guts', you'll need a jeweler's screwdriver to remove these screws (I counted 3 of them).
    The battery is right under this cover.
    When re-assembling the watch, I would apply a thin coat of sewing machine oil, or some other non-reactive lubricant, to the black gasket seal which should be on the back cover of the watch.
    Jul 10, 2012 | Elgin Watches
    How do I open the back to change the battery on my timex e tide/temp watch
    you had to have a knife caseback opener or any flat tools. look for the small opening on the back located on the upper right side of the caseback, insert the flat tool inside of it and just flip it up. then it pops out. note: after you had change the battery, you had to use pressing tools to cover it again because it cannot press by hands to seal it. it uses CR2016 size of battery. i hope i had been helped you.
    Aug 20, 2011 | Timex Watches
    I was just wondering how to remove the back of my watch so I could change the battery? Model AM-4065. Thanks for the help
    To open the back of a Fossil Am-4065 your best bet is to use a watch case opener like this
    You can also use a pair of needle nose pliers, but you then run the risk of damaging your case back. I would advise against it. I've had to deal with quite a few watches that were damaged in such a way.
    The opener has an assortment of small pins. Usually you will be able to find some that will best correspond to the size of the grooves on your watch. Then the case opener can be adjusted so that the pins are securely fitted to the grooves so that you can then turn the case back off.
    You will need to hold your watch securely while turning the opener, or it may slip out of the grooves and damage your case back. This is not a difficult task, you just have to go slow and carefully.
    After you do so you should be able to carefully pop the battery out. Do not use a small screwdriver or other metal tool to do so. It can damage your watch. You can usually use your fingernail. After you do so you can simply read the battery number off and find a replacement. Many grocery store/drug stores and Radio Shack carry an assortment of watch batteries. You can also go to a website like Battery Bob and order the battery, but for one battery it may not be worth it.
    Your watch will not have the same water resistance after you open it. Usually a watch like this will at least have it's case gasket lightly wiped with silicone grease before it's re-closed (or have the gasket/O-ring replaced and treated with grease). This should not be a problem if you don't swim or bathe with your watch on.
    Feb 28, 2011 | Watches
    How do you change battery for casio 1174 CMD-40?
    I like these little RC IR watches. They're great fun!!! For this tutorial, you will need....
    • A small Phillips heads screw driver
    • A pin (or needle)
    • A replacement CR2032 battery
    Instructions :
    1. Remove the 4 screws from the back of the watch
    2. Carefully remove the back plate, do not damage the delicate rubber seal
    3. Carefully remove the delicate rubber seal
    4. Use the pin to remove the small rubber block from the battery cover clasp.
    5. The pin should then be inserted in the gap of the white plastic lug, where the rubber block was removed.
    6. Use the pin to gently pull back the clasp of the battery cover.
    7. The battery cover will then open with a 5mm gap approx. It does not need to be removed.
    8. Use the screwdriver to remove the battery.
    9. After the battery has been replaced, just follow the instructions backwards.
    I hope this little tutorial has helped.
    Feb 10, 2011 | Casio Watches
    Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    I have a Majestron quartz pocket watch. How do I replace the battery?
  • Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
  • Remove the circular watch battery out of the back of the watch.
  • Take the battery to any department store or watch store and purchase a new replacement battery.
  • Insert the new battery into the back of the watch.
  • Screw on or push on the back of the watch. Set the watch to the correct time.
  • Aug 23, 2010 | Watches
    HOW TO CHANGE BATTERY ON AN OAKLEY BULLET WATCH
    Open the watch case back, release the upper contact (unclip or unscrew it), memorize the writings on battery and the way the battery was placed in. Buy exactly the same battery, insert the same way in and close watch case back. Reset the watch and you are done. Some watches need a shortcut to be made before resetting. This should be written on the label covering the battery. Rate me, plz.
    Mar 15, 2010 | Oakley 4 D Bullet Watch Titanium Case with...
    During a workout my watch stopped working it appears to be frozen and will not do anything
    NO, don't open the back cover you will break the water seal.
    Reset the wrist unit. Resetting clears the date and time settings.
    Press all buttons except the Light button at the same time until the display is filled with digits. Press OK.
    If this does not work, have the batteries checked.
    Oct 19, 2009 | Polar F6 Wrist Watch
    My watch needs a new battery.
    There is a tool that you need that adjusts to the three holes or openings in the back of your watch and it just screws off. If you don't have access to the tool, simply take two push pins and CAREFULLY insert them into the openings and unscrew the back cover. Remember that it unscrews counter-clockwise.This will give you access to the battery simply take it out and go to the store to buy a replacement repeat the process to install the cover back on.
    Nov 10, 2008 | Swiss Army Wenger Sportedge Bracelet Watch
    I have a Timex Ironman Triathlon Speed + Distance...
    The Timex Ironman manual and website says to take the watch to a repair facility. Nope! Do it yourself!
    How to replace the battery in a Timex Ironman watch:
    This is easier if you remove one of the rubbery wrist bands.
    1. Take note of the position of the metal back cover. You'll need to reinstall it exactly as you see it in order to hear the alarm.
    2. Remove the four screws that hold the metal back cover, and pry off the cover.
    3. There is a round metal clip that holds the battery in place, covered with a transparent plastic cover which likely says, "Unlatch to remove battery". Within the center of each clip, there's a small opening just large enough for a straight pin to be inserted. A jewelers screwdrive won't work - use a straight pin. Insert a straight pin into the tiny opening at the edge of the clip, and wiggle it. The clip should release. You'll only need to unlatch one side of the battery retaining ring.
    4. Gently pry up the batter retaining clip, then pry up the battery. Insert new battery.
    5. Replace the clip.
    6. Insert a flat blade screwdriver into a slot which has two "electrodes" or pins - they need to be shorted with the screwdriver to reset the watch. Just touch the screwdriver blade across the two pins to short it.
    7. Reinstall the back cover but be sure to position the cover so the alarm sounding place ( a small disc attached to the inside back cover) will reside over the sounding spring.
    8. Insert screws.
    Dave
    Oct 01, 2007 | Timex Sports Ironman Triathlon 100-Lap...
    Fossil Metal Dress Silver Dial ES1053 Watch for Women Logo
    99 people viewed this question
    Top Fossil Watches Experts
    Ansel Alberto
    Ansel Alberto
    Jimmy Accardi
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
