Question about Estate TS22AFXKQ Side by Side Refrigerator
I HAVE THE ESTATE FRIDGE AND I CANT SEEM TO FIND THE WATER FILTER SO I CAN CHANGE IT ?WHERE WOULD IT BE ?
    Problem Solver:
Usually the filter is under the refrigerator side .open door look behind bottom panelor in frig compartment behund panel
Posted on Aug 23, 2010
Changed filter and now water flow is limited
If the water shutoff valve has a seal like a faucet instead of a saddle valve it's possible a piece of it has broken off and is partially blocking the water line to the fridge. Check the line to see if you can see it or disconnect the line at the inlet to see if the filter screen is plugged.
May 10, 2017 | Maytag Refrigerators
How to change the water filer on a rf4267hars 25.5 ft
You must shut the water valve to change the water filter. If you don't havewater valve near the fridge, shut the main water valve for few minutes. If you turn the water filter to change without shutting the water valve, lots of water flooring the fridge and you do lots of work to remove the water inside the fridge. Shut the water valve, and then replace the filter. Then turn the water valve.
Apr 02, 2013 | Samsung RF4267HARS 25.5 Cu. Ft. French...
I am trying to change my water filter for my viking fridge. I have removed the unit from the base of the fridge, but cannot seem to get the cap off of the unit to instal the new filter. The instructions...
When you turn it counterclockwise it will stop. then.. oops is the water off? then once it stops pull down on it and it will release from the head.Reverse procedure to install.
May 11, 2017 | Viking Refrigerators
We have an Estate Whirlpool Side by Side Fridge and the water filter is leaking. Should we change the filter? When we remove the filter the dripping stops but as soon as we re-install the filter and twist...
You have done some good work, and you are right on the money. Yes you need a new filter. There are o-rings that seal on each filter. These wear out but when you replace the filter you naturally get new o-rings and they seal better :) These seals used to be in the housing, but you can see the problem with that. Once those wear out, you have a much worse problem replacing those then with a filter. It's perfect really, you change the filter because you have too, and get a new seal at the same time!
May 30, 2010 | Whirlpool Refrigerators
Whirlpool water dispenser ...metalic taste
Hi!!! you seem to have a bad water valve in your refrigerator.change your water filter and the water valve on the back on the frig..
Jan 03, 2009 | Whirlpool GD2SHGX Refrigerator
Cant get water out of the fridge door
hello allamericananp,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Remove the water filter
Yes if it is the filter that is located where the bottom grill is..... It rotates 1/4 trun counter clockwise. If you cant seem to break it loose try removing the grill by pulling it towards you (it clips on) take not of the tabs on the grill and the clips on either side of the fridge. Now you can get a better grip. Also its a good time to look and see how dirty coil is under refrig.
Jan 19, 2008 | Whirlpool 21.8 cu. ft. Side-By-Side...
Refrigerators Logo
111 people viewed this question
Top Estate Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steven Clarke
Steven Clarke
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
