Question about Frigidaire GLWS1649A Top Load Washer
I have water leaking out of the bottom of the washer onto the floor. Might be the drain line is clogged, Trying to figure out how to open the unit up to inspect. Machine is not that old and hasn't been used too much.
  • 176 Answers
Check the drain lain
and water bumb
Posted on Aug 23, 2010
Where is the access to the drain located on a whhirlpool WFW94HEXW washer
bottom front of the washer behind the panel is the common location of the drain pump and inlet screen.
Sep 27, 2016 | Whirlpool duet Washing Machines
We have a Kenmore Elite 795 fridge. It is constantly leaking water from the bottom right corner of the unit onto the floor. There always seems to be a build up of ice at the bottom of the unit.
Usually the result of CONDENSATION due to eithr bad door seals allowing air and moister in to condensate. or a plugged or clogged evaporator drain line which causes water to back up and freeze or leak out the lowest point the bottom?
Mar 19, 2015 | Kenmore Refrigerators
WFW9400SW01
Determine first if you hear any noise when it is trying to drain. If you do, the drain pump is getting power. Unplug the washer and remove the access panel below the door. There are screws across the bottom. With the panel removed, you will see the drain pump sitting on the floor on the right side. There is a cap on the front of the pump that can be unscrewed. Be careful as there could be a sunstantial amount of water that drains onto the floor. Have plenty of bath towels ready. Sometimes by tipping the washer back against the wall will cause the water to flow to the back of the tub minimizing the amount of water that will leak onto the floor. Now unscrew the cap and remove it. Look for any debris in the trap and around the impeller area of the pump. After cleaning it, reassemble everything but the front panel and try draining it again. If it works you are all set. If not, you may need to replace the pump as it could have burnt out
Feb 07, 2014 | Washing Machines
My maytag refrigerator is leaking water from the freezer drawer. what do i do
More than likely the drain line coming from your freezer is clogged. Take everything out of the freezer. The drain line should be right below the evaporator. Usually in the bottom back of the freezer. First try pouring hot water down it then try anything long and skinny to unclog it. A lot of the time it is just ice clogging it so the hot water will do the trick though. This can happen simply from the door being left open on the freezer or something more serious like there being a problem with the defrost cycle on your freezer. Just be careful after you unclog the drain line to not leave the door open and if it starts being a problem again soon then you may want to call a technician.
Mar 18, 2013 | Refrigerators
My Bottom pull out freezer is leaking water onto the floor from on top of both feet of the unit. The freezer also has frozen water in the bottom of the unit. I have removed the frozen water in hopes that...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 15, 2011 | Whirlpool GI5FSAXVY Stainless Steel ...
Frigidaire FRS26ZNH frig is freezing water in the bottom of the freezer and is leaking water onto the floor.
Hi
The drain hole is clogged. Remove the food and do a complete defrost. Most of the time the blockage is caused by ice in drain line. If that does not fix the problem, the drain hose to evaporator is clogged. The drain line (TUBE-DRAIN) is part 64 in diagram below. Click on the picture to enlarge:
Jul 15, 2011 | Frigidaire Refrigerators
Washer and dryer stackable unit. water is leaking from somewhere onto the floor causing floor swelling. what could be the problem?
Thanks for choosing FixYa and welcome to the sight. You need to make sure your drain hose is not clogged up or your hoses are not damaged. You need to check the water pump also. It may be clogged or leaking from the pump area. Make sure the tub is not cracked or damaged, causing water to run out. Your best bet is starting the washer while you are viewing the hoses and the pump. You should be able to find the leak this way.
Apr 22, 2011 | GE WSM2420T Top Load Stacked Washer /...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mar 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidaire GLWS1649A Top Load Washer Logo
115 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
