Question about Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP)
When i turn the first gas knob on it has a rush of gas sound coming out. then as i turn the next two knobs on it almost eliminates the falme from all the first burner and has no flame on the other two burners. help i am craving a grilled burger. paul
  • 43,501 Answers
That would be a regulator problem, assuming that the gas tank ain't almost shot...
Get a new regulator and that will get you that burger...
heatman101
Posted on Aug 24, 2010
Is making a random clicking noise
Sounds like the piezoelectric igniter is coming on when your knob is turned. Older knob may be lose and twisted make sure it does not spin on the knob shaft
Oct 18, 2011 | Hotpoint RGA724EKWH Gas Range
Burner stays on,after turning off
you could have a bad switch behind the knob or the knob isn't turning it off,pull off the knob and see if the metal clip that holds the knob on tight didn't slide up on the shaft,if it did pull it off with a needlenose plyers and stick it back into the knob,next time send the model number and if it's gas or electric
Jul 08, 2011 | Kitchen Ranges
Viking gas grill - when I turn the knobs to lite up one of the burners, it rushes out the gas with a loud hessing sound. also there are flame coming out from where the gas comes out and goes into the...
What you have described sounds like a clogged burner as well as the venturi valve on the burner. Your will need to remove the burner to clean it and the venturi valve on the open end of the burner, that goes over the burner orifice. Spiders like to build nest in them and clog them up. The venturi valve will look like two slots, cut in to each side of the burner, at the open end. It's function is to mix air with the gas, for proper combustion.
Hope this helped you to troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 16, 2011 | Viking Grilling
I have. A 40 gal. 40,0000 btu natural gas , how do u lite the pilot light
Access is at the bottom of the water heater. There is a little cover you will have to take off. Look for the gas valve. (its where the gas will come in to the water heater) Follow the two lines that come off he bottom of the valve. They will lead you to the burner (big line) and the pilot(smaller line). The pilot is what you are looking for.
1. locate the pilot (it will be 8" or so in to the water heater)(right next to the burner)
2. Turn knob on top of gas valve to "pilot"
3. Push down the knob on top of the valve that you just turned to "pilot" or there may be a lever right next to the knob on some models
4.with a long fireplace match or bar b que lighter, while holding the knob down, reach your lighter to the pilot assembly. you may smell a little gas.
5. The pilot will light, do not let go of the knob for 30-45 seconds
6. After a few seconds let go of the knob and turn it to "on"
7. Check your thermostat make sure it is not on "vacation" and turn it up to see if the burner ignites.
You are ready for hot water if all works. Hope this helps you, have a good day.
Apr 18, 2011 | General Electric Water Heaters
I have a brevis buffalo central heating unit . It does not have a series number so I think it is an older one. I have not used one before. I am trying to find the pilot light to light but I don't know...
Well there is a first time for everything. If you notice there is a pipe coming into the unit and a big usually grey box with a red or white knob on it. This is the Gas valve you have to turn the knob to "pilot" position and either hold the knob or the button next to the knob down in order to get gas to go to the pilot. You will also notice a small pipe coming out of the gas with a copper tube running with it follow it to the end and this is you pilot and themal coupel. That is where you will lite the pilot. You will have to hold the knob or button down for about 1 minute after you light it then turn the knob to the "on" position. Make sure that you replace all the doors as some have safety switches and the unit should work.
Mar 02, 2011 | Heating & Cooling
Can't get it lit
instruction on a metal plate inside the fp bottom door
the knob will have pilot/ on/off marked on it on gas valve, you have to line the pilot word up with the white mark on valve then knob can press all the way in, now press it in hit the res or black sparker button and you should get pilot falme in a few tries, once you see flame keep the button in on valve for 30 secs then release turn it to ON and turn youe switch on
Nov 13, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Gas does not flow when you turn on gas knob when you turn on the gas valve on the tank and then turn the knob for gas to get to the grill, just before you hit the ignighter no gas comes out
make sure there isn't a designated burner for lighting. sometimes there will only be 1 burner the grill will light. start with all them off, turn on the tank. the grill will have a little picture of a flame next to the burner knob. turn it to high and try lighting
Jul 15, 2009 | Weber Grilling
3 of 4 knobs do not compress to turn on gas
You must replace those controls. Cleaning or loosening them up would be temporary at best and the next time they stick it could be in the open position. Safety first...Eric
Jun 14, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Oven wont come obut igniter works
Yes, it could be the knob or the oven control.
If the knob fits tightly to the control, and turns the stem of the control, then I would be suspect of the control. But if the knob fits loosely, I would be suspect of the knob.
Jan 29, 2009 | Frigidaire FGF316 Gas Kitchen Range
Oven
Hey ascollins217
This is normal with a gas range. The oven is lit with an ignitor (the glowing that is seen) - it glows first then the gas comes on and lights up shortly afterwards. There is no clicking sound for the oven (at least not for the model you have)
Regards
Sep 06, 2008 | Frigidaire FGF316 Gas Kitchen Range
Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP) Logo
222 people viewed this question
Top Brinkmann Grilling Experts
paulcarew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
