Question about Ryobi 9 in. Benchtop Band Saw
I can't get this saw to cut straight or square I
I can't get this saw to cut straight or square I have tride ever thing
  • Ryobi Master
  • 885 Answers
Band saws pull to one side on straight cuts, it's a function of the blade torque. My 14" saw pulls to the right. There's nothing you can do to stop this, you have to be aware of it so you account for it on free cuts and know to put your fence on that side so the wood pulls into the fence instead of away from it. Squaring the blade to the table is easier. Do not go by the tilt angle guide. First make absoutely sure all of your blade guides and bearings are properly alligned so they aren't pushing the blade out of line. Use a square to get it close then: using a 4" x 4" block of wood, make a light cut in the wood only deep enough to mark the wood from top to bottom. Turn the block over 180 and try to make a cut in the previous cut mark. If the cuts line up you're there. If you get a V or X you have to make adjustments to the table making sure you tighten the trunion locks tight. I had one of these, it's not a high end saw so don't expect a lot from it.
Posted on Aug 23, 2010
My craftsman miter saw cuts but it is not a straight cut.
Here's an old dude trick that might help.
Safety first! UNPLUG THE SAW.
- Take a framing square and set it against the fence. It should be flush with the fence on both sides of the blade. If not, slide the square to one side and pull the blade down into full cut position, then slide the square against the blade and fence to check for square. If square, slacken the bolts on the other half of the fence and align it with the correct side.
- A bit of messing about should have it lined up just fine.
- If it is off vertically, there should be some alignment possible.
Patience and safety.
You'll get it.
Oct 08, 2015 | Craftsman Saws
Square up fence to blade
with the tool unplugged from power . u need a good square drop the blade down to cutting position place thesquare against the fence then slide it up to the teeth on the blade making sure u are against the teeth . if not square in the zero position on the scale undo the fixing bolts for the fence and adjust till the square shows no gap between fence and blade teeth . retighten bolts and check . plug in and make a cut . or u could just make cuts and move fence till get it right . i should add with straight edge make sure the fence itself is straight across its face. with one piece fences they can get bent. good luck.
Aug 14, 2011 | Makita 10" Miter Saw LS1030N
Saw cuts bevel at 0 degree setting. Needs to set to about 3 degrees for square cut. Multiple saws with this problem. Is something bent, or worn out?
Check that the bed of the saw (the flat metal part on the bottom) isn't bent. I've had this sort of thing happen on a jigsaw that needed to be tapped back into square. Check the squareness of the saw with a framing square or a carpenter's square held against the blade and the bed of the saw with the blade guard open. Obviously, make sure the saw is unplugged before doing this.
Jul 28, 2011 | Makita Circular Saw - 15 Amp, 7 1/4in....
Have kalamazoo 9a saw .Will not cut straight vertical cut at 22.5 degrees
Have you tried to adjust the side guides (bearings) with the excentric pin? they must be touching booth entirely sides of de band saw. Also check the band tension and the guide alignment to the saw bed with a square.
Feb 23, 2011 | A & A Manufacturing Kalamazoo 7a8a9a13a...
Craftsman radial arm saw will not cut straight. Even when I line up the blade with a square and try to cut a piece of wood with a straight line it cuts at an angle or a bevel instead of straight. Any...
All of the adjustment locks should be tight. Check the arm and saw motor cradle for looseness by trying to push/pull the blade, cradle, and arm in various directions. A bevel cut indicates that the motor/cradle is tilting. An angle cut is controlled by the rotation of the arm. Check for looseness of the cradle bearings that allow the cradle/motor to roll along the arm. If you don't have the owner's manual for this saw, go to: www.searspartsdirect.com and enter the complete model number minus the decimal point--this will take you to a series of drawings that detail every replaceable component of the saw. The owners manual should be available there. There is a rather involved series of adjustments involved to make this saw work correctly. Hope this helps!
Jan 05, 2011 | Craftsman Garden
I dropped my saw and the base is no longer square to the blade. As a result I can no longer use a straight edge as a guide for cutting sheet goods. A straight edge mated to an out of square base puts the...
It can be first determine where the misalignment is and it might something as simply as loosening a screw and drawing the base back to square, if not the base would have to be replaced and then realigned. it is not that difficult
Dec 26, 2010 | Skil 7 14" Wormdrive Saw With Twist Lock...
I have an old Craftsman 9 inch table saw that will not cut straight. When you set the fence and get evrything ready it cuts at an angle. A 1x4 will not cut straight it always cuts at an angle. Is there a...
unplug the saw then:
turn the saw over or, get under it; there is a long bolt that sets the
saw motor tilt two nuts jam lock it; release the nuts and adjust the saw using a t-square for 90 degrees.
Jul 31, 2010 | Craftsman Saws
Why my chain saw always cuts at an angle
a lot of people have this problem with a chain saw and cant get a strate cut, most of the time its down to them trying to force the saw through the wood and in doing this the saw cuts around corners as there pull is not square to the cut,, let the saw do the work, not you, if your pulling on the saw to make it cut well then it has a very dull or blunt blade,,,is there any side to side "rock" on the chain in this new bar? how have you sharpend it? dose the chain have the same pitch on both side's? are all the teeth cutting at the same depth? if its cutting around corners it could still be the chain pitch worn out, if so the chain is past its best as well, but most of the time its all down to how hard and how squarely your pulling on the blade when cutting,,,the first thing in logging to lurn is to cut squarely no easy task that! just dont force the saw to cut!! it will cut just as fast or faster without forseing it,, if all this still dont get you cutting right change the chain for a new one,,,the only hard work with a chain saw is holding it up to the tree and humping it around not cutting with it, thats the blade's job to do so the faster you try to make it cut the more out of true the cut go's as all your doing is bending the bar out of alinement,,all in all, its two hands for the job and a very gentle pressure on the saw, start the cut with the blade spinning and dont stop the blade in the wood, cut right through
Mar 28, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Need to adjust Miter gauge for Delta tablesaw 36-977. The 90 degree stop is off
1) Before setting the Miter gauge, check that the blade is straight (parallel) with the slide grooves. Lock a board in the miter gauge and place against the front of the blade, and then the back of the blade. Is the distance EXACTLY the same (it won't matter if the miter gauge isn't straight and square). If not, you'll need to loosen the table and rotate the blade holder to square it up.
2) Now Cut a board in half the flip one side over and place the cut back together. If it isn't straight, the resulting board will have a "dog-leg".
3) Adjust the miter-set-screw until the cuts on the trial board yield a board that comes out straight (or use a Framing square to check).
Dec 31, 2009 | Delta 36 977 Left Tilt Contractors Saw
I HAVE THE JET 414458 HVBS SAW.THE SAW CUTS ROUND STOCK CROOKED.IT LOOKS LIKE THEBLADE IS IN CONTACT WITH THE STOCK AT THE START OF THE CUT AND ABOUT .250 AT THE END OF THE CUT THE STOCK IS 1" IN DIAMETER
There are two possible reasons for your band saw to cut crooked.
1 is the set on one side of the saw blade has worn down and you need to change your blade, or
2 your band saw blade is not square to the bed of your band saw.
If the blade is brand new and it still cuts crooked then you need to square the blade to the bed. To check if the blade is square to the bed, lift the head of the saw up a couple of inches and take a square and set it on the bed. Slide the square up to the blade and to see if there is a gap between the edge of the square and the blade. Try to pick a spot on the blade where the tooth is straight or bent away from the square. If there is a gap you'll need to move both blade supports in or out until there is no gap between the edge of the square and the blade.
If you are unable get it squared yourself, contact the place you bought the saw from. They maybe willing to send a service tech out to do it for you. Some band saw blade makers are also willing to send a service tech out to correct any problems that you may have. Lennox is one such company that may send a service tech if you are using their blades.
Hope this helps you,
Hatter1
Mar 06, 2009 | Jet 414458 HVBS - 56M Horizontal/Vertical...
Ryobi 9 in. Benchtop Band Saw Logo
291 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
