Question about Epson Stylus C60 InkJet Printer
I haven't used my epson C60 for three years approximately - just got new ink and I thought I installed the printer properly on my computer but it is printing blank pages. It goes back and forth as if it's printing and the ink levels show full when I go to the printer properties but nothing is coming onto my pages! I have Windows Vista if that means anything.
  • 37 Answers
Hi It is probably the printer not the OS first because the printer has been idol for so long it is more than likely the the printheads are covered in ink or have dried ink in them first try recovering the printheads a good few times then if that fail get a sponge you use to clean dishes get sissors and cut the abrasive part of and try GENTLY aline it under the printhead carriage. best way is as the printer is initalising and you hear the carriage start to move pull the power this will let you get to the carriage without damaging it. Then comprise the sponge have two a wet and a dry one and have the sponge under the carriage the wet one first. And move the carriage from side to side you should see the sponge darks with the ink coming of then the dry spong. Then the wet and then the dry. after a bit remember to wash the sponges if you cant get a songe try a cloth. If this doesnt work you might have to try to strip the printer down.
Posted on Aug 23, 2010
  • Epson Master
  • 17,129 Answers
Remove the printer and uninstall. then reinstall the printer software back to the PC, the reconnect the printer to the PC . the printer will be detected and the new hardware will be installed.
Now do a test print, if not try a head cleaning using the maintenance key. If this wont work the printer head is faulty.Check cost and decide.
  • 61 Answers
Double check to make sure the packaging material is removed and that the cartridges are inserted properly.
Will not let ink cartridge (black) in printer?
Switch it off. Leave it a minute or two. Switch it on again. This should allow it to reset.
Let me know if your problem is solved and rate me as FIXYA!
Jan 07, 2009 | Epson Stylus C60 InkJet Printer
Installed H/P 6300C scanner now epson C60 wont print any idea how to remedy ? lite for out paper or ink comes on text says communication error . Many thanks *****
The H/P 6300C can be plugged right into you router using a network cable. then you can plug your epson C60 back into your computer.
Jan 04, 2009 | Office Equipment & Supplies
Epson c60 printer not compatable with windows vista need a driver but have no idea where to download it
The driver for the Epson C60 printer is included with Vista - all you need to do is connect the printer to the computer with Vista running and turn it on. If you have already done this and the printer does not work properly (but see the info about the Status Monitor below), turn the printer off, uninstall the printer using the Control Panel-Programs and Features-Epson Printer Software, then reboot the computer. Once Vista is running, turn the printer on and it should then install OK.
HOWEVER, the printer Status Monitor (SM) is not included in this process and if you try to install the XP version of the SM, it will not work. Epson appears to have no intention of remedying this problem. This means you have no means of monitoring your ink levels, nor of changing the cartridges, cleaning the heads etc via the computer, although some of these tasks can be carried out via the printer control panel (see your hand book on how to do this).
A good solution is to use the free SSC utility as your SM - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C60), then close the ssc window. Now right click the ssc icon in the sytem tray and choose the SM function you wish to use.
If you have any further queries on this, please post a new comment.
Oct 23, 2008 | Epson Stylus C60 InkJet Printer
How do I clean and maintain my Epson Stylus C60printer?
Kesha,
In order to find out if it will work you have to get new cartridges so the printer can print. The printer can sense if the ink is to low and can cause it not to work correctly.
Hope this helps
Jul 16, 2008 | Epson Stylus C60 InkJet Printer
My troublesome printer
New ink comes with a strip attached at the ink hole and sensor area, makes sure u ermaove them also try to clean the catridge contacts in the printer
Mar 06, 2008 | Epson Stylus C60 InkJet Printer
Epson c60 will not print with windows 95 gateway computer
take the cartridge out clean the contacts with a cotton bud re-insert ana dtry a cleaning process via the HP software sometimes even with a new cartridge it will not print emediately
Feb 16, 2008 | Epson Stylus C60 InkJet Printer
Epson C60 inkjet Epson Printer Utility
Try downloading the latest version of the status monitor from the Epson web site. This should sort your dilema.
Apr 01, 2007 | Epson Stylus C60 InkJet Printer
Epson Stylus C60 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
