I have a panasonic 65" LCD TV that has developed a yellow discoloration in the middle of the screen. Everything around the edges is the proper hue/tint, but everything toward the middle of the screen is dingy yellow. It does not appear to be anything on the outside of the screen itself. What could be causing this and how do i fix it?
  • fiestatoad Aug 23, 2010
    I wouldn't know how the panel could have gotten damaged. It has not been moved since we brought it home. It sits in a recessed area of the wall. Does anyone else have any other ideas? substance on the lamp or the internal mirrors (if there are any mirrors in an lcd tv) perhaps?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that the inverter board is fine so it is either the T-con board in the unit has gone bad and/or it is not getting the required 12vdc from the power supply unit. If you have knowledge of internal circuitry of the unit then you can open the back of the unit and check the T-con board which is the last board before the LCD panel. Usually it is available with the LCD Panel. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
  • 11,800 Answers
The LCD panel itself has been damaged- either the panel has been pressed upon or the mountings have deformed the case and it has deformed the panel.
The damage can't be fixed, it's permanent. Either use the tv as is or buy a new one.
  • Azrael SRL Aug 23, 2010
    The image has a yellow tint because the pixels in the center are no longer properly controlled. Because the damaged zone is irregular the damaged zone can't have an electrical/command cause. This only leaves physical damage or lighting error. For the cause to be in the lighting would mean that all the CCFL tubes have suffered the exact same very weird failure (a color shift in the emitted light) at the same time - it's practically impossible.
    That only leaves physical damage. How that happened i don't know, but it did. And it's unfixable.
Screen is yellow in the middle?
If the yellow area edges are sharp then the blue LCD is faulty and need to be replaced.
If the yellow area edges are not sharp and you get the multi color background in you image the your need service. due to dust on LCD panals the light is not pass on properly so you open the projector and clean the LCD block.
(cleaning of LCD block and other parts of the projector is a very technical job please very very carefully)
Jan 25, 2011 | Panasonic PT-AE1000U LCD Projector
The direct tv menu guide is cut off around the edges...how do i fix?
Your TV resolution is not set to the proper screen size for viewing it properly and it probably cuts off your tv shows too and you just don't see it. Press the [FORMAT] or [ASPECT] button on the remote. The option available to remove the horizontal bars is Zoom.
Nov 04, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Yellow/green tint moving toward the center of the screen
Bad news the blue uv cut filter is discoloring its in the optical engine.
You are one of the many sony tvs that have this problem.
GOOD NEWS - sony will pay for yours
http://esupport.sony.com/US/perl/news-item.pl?news_id=115&mdl=KDFE42A10
Thanks
scott
May 08, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony 60" LCD projection TV has yellow screen discoloration
It sounds like you have a bad Blue Polarizer in the light path. I'm sorry but that is something you will have to contact a service center for. It's not something you'll be able to do yourself, I'm sorry, but that's the best advice I can give you.
Feb 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Yellow discoloration on screen
the screen is yellow green color all the we have had it worked on once already does anyoblemne have any comments on how to solve this problems?
Jan 27, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Yellow and blue on screen
I am slightly confused about the model of the television, because a 46F500 is a rear projection set that doesn't have a lamp. It has 3 picture tubes and I have a few of them in my shop right now that have the problem you reported. What we do to this set when it develops a convergence issue is to check each resistor around the convergence chips for discoloration, and replace any of them that have changed in value, along with the STK392-150 ic's. If you don't have an ohm meter and solder/desolder equiptment, you can usually get a shop to do this repair for 150.00 to 350.00. Parts will be 50.00 and labor , the rest, depending on the quality of repair shop that you use. Good luck, Russmann.
Nov 16, 2008 | Hitachi 46F500 46" Rear Projection...
I would suggest to try to get this TV fix while still under warranty. Normally the manufacturers give one year.
In regards to the discoloration, there is not much you do but to let the Sony authorized repair center knows about it so they can fix it. Ask them if their work is guarantee as well for how long.
Good Luck.
Feb 25, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
2005 Panasonic LCD TV Model# TC-26LX20
I am also having problems with the same year and model number panasonic, it is at the repair shop now. I think it is a lemon tv. won't buy panasonics anymore. Tried all the fixes recommended by panasonic. It happens after the tv is on for longer than 1/2 hour. It happens with dvds and different hook ups. my samsung is fine on all the same connections.
Aug 16, 2007 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
