Question about Black & Decker SpaceMaker ODC325 Coffee Maker
The coffeemaker starts to come on and brew, then it just stops
    New Friend:
  • 47 Answers
Try this solution. It should fix the problem.
Posted on Jun 11, 2011
Won't brew ground coffee.
My idea would be for you to supply a brand and model number.
Mar 17, 2015 | Coffeemaker Coffee Makers & Espresso...
My coffeemaker will not stop dripping after the coffee is brewed
If this is a small brewer it's most likely that the brew valve is not closing fully after the batch. This is often a result of the plunger inside the valve having a worn seat. Without knowing the make and model it is not possible to give much more detail.
Dec 13, 2014 | Coffeemaker Coffee Makers & Espresso...
Coffeemaker shuts off in the auto brew cycle
Your Cuisinart coffee maker probably is defective, though new.
Jan 10, 2018 | Cuisinart Chw-12 Coffee Plus 12-cup...
Why is my coffeemaker taking more than 4 minutes to brew a pot of coffee
  1. Be sure that your SPEEDBREW® Coffeemaker brew control dial is set to 'Brew Regular' when brewing regular coffee. Please note that using the 'Brew Decaf' setting will slow the brewing process. It is recommended that the 'Brew Decaf' setting be used when brewing decaffeinated coffee.
  2. Your SPEEDBREW® Coffeemaker may need to be cleaned.
Sep 02, 2011 | Keurig B50 Coffee Maker
Cuisinart coffeemaker won't brew
A common problem that can occur with the Cuisinart coffee maker is it will stop brewing, even when there is water ready to be transformed into coffee. The machine still turns on and works like it should, but does not continue brewing an entire pot of coffee, and acts like it has finished brewing even when there is still water sitting in the bin. This type of problem is pretty common among various coffee makers, and usually occurs when there is a problem inside the machine.
One of the best ways to fix this problem is by flushing the coffee maker out with a vinegar solution, which can be made with equal parts of vinegar and water. It should be poured in the same place as the water that is ready to be brewed, and will help to clear out the machine and make it ready to start brewing again. This problem is usually caused by calcium building up within the machine, and the vinegar helps to clear out any blockage to help it start running smoothly again.
Nov 01, 2017 | Cuisinart Coffee Makers & Espresso...
Set up for 12 cups. Starts ok but stops after
Unplug the coffeemaker for 20 minutes OR LONGER (not a second less). While it is unplugged, fill the water reservoir with 1/2 caraffe distilled white vinegar and 1/2 caraffe water. At the end of the twenty minutes, replug the coffeemaker and brew the vinegar/water just like it was coffee. You may have to run it through up to 3 times. If the vinegar/water cleaning fails to restore the coffeemaker to normal, you have a deeper issue. This product has a 3-year warranty, so call Cuisinart if you are within your 3 years.
-Tha Mp3 Doctor
Mar 22, 2009 | Cuisinart DCC-1000 Coffee Maker
Coffeemaker will not brew a full pot
Try cleaning it with pure vinegar. 3-4 times just keep running it through the machine.
Jan 12, 2009 | GE 106591 Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
I have the same problem with the exact same coffee maker I have tried pushing the 1-4 cups button. That worked for a couple weeks, now it is back to only brewing half the water in reservoir whether I push the 1-4 button or not. It is very annoying.
Nov 14, 2008 | Cuisinart DCC-1200 Coffee Maker
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
52 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Lyle Siemens
Lyle Siemens
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
