Question about Video Game Consoles & Games
Dear fixya i have got original sixaxis sony wireless ps3 controller and left analog stick keep jaming in up position.is there any way to fix this problem or will i have to buy a new one.thanks for help
  • 4,323 Answers
Hi
Please take out the batteries and use a Q-tip dipped in alcohol to clean the area around the stick, let it dry and check after a while. If it doesn't work now then you would need to take it apart to clean it and if required would need to lubricate it. However, if it is under warranty then I'll suggest you not to repair it at home as it will void the warranty.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 23, 2010
Ps3 controller manual
You plug in the usb cable to charge the controller and connect it to the ps3 for the first time. You use the left analog stick to move around the dashboard when the ps3 is turned on and the 'X' button to change settings, go to the online browser, playstation store, or start a game. You can back out by pressing 'O' or holding the 'PS' button, which allows you to change a controller number (say controller #1 to #2 with two controllers), turn off the system or turn off the controller. Press (not hold) the controller to look around the dashboard while in a game and select say "Quit Game', or go into settings and change something around to your liking. Every game also comes with the controls and for what the buttons are. (Stick on left is the, "Left Analog Stick," right is "Right Analog Stick," from right to left starting at the green triangle shaped button is the, "Triangle," "Circle," "X," and "Square," buttons. The four buttons on the left going in all directions is the D-pad, and the triggers on the back going from the top left to bottom left and top right to bottom right are, "L1," "L2," "R1," "R2").
Feb 05, 2013 | Sony PS3 DualShock3 Wireless Controller...
I just turned my ps3 system on and my controller seems to be pushing all the way to the right everytime i hit left(directional) it pushes back to the right like a fight i cant win :( i need help asap
Hi.
There is probably something stuck under one of the analogue sticks or the crosshatch button. Like a hair or crumbs for example.
You could try and open up the controller and clean the internal parts that control movement. However, be very carefull if you do this as there are parts that can fall out and be very difficult to put back in place.
If after this the controller still banks to the right you will need a new controller.
Regards.
May 17, 2011 | Sony SIXAXIS SCPH-98040 for PlayStation 3
Right analog on ps3 gets stuck on top left direction
the circular thing that lets it move freely probably cracked, making it harder to move. i had to buy a new controller because of this reason.
Dec 03, 2009 | Sony Playstation 3 (PS3) Console
My controller is original dualshock3,...the stick and the pad when i turn on the ps3 on the xmb menu it rapidly goes stuck to the left any ideas before i buy another ps3...HURRY!!! i won't hold much...
Have you tried using a different controller? Usually this is the problem, your PS3 controller's D-Pad is stuck on the left side or the responding piece beneath the D-Pad is being pressured down in some manner. I recommend trying a Different controller first before buying another PS3 ( get a cheap PS3 Arcade stick or something)
Nov 17, 2009 | Sony Wireless Controller for PS3
Sony ps3 wireless controller not recognised
all you have to do is connect it with your usb to mini usb cable and press the ps button then it should connect and you can unplug it
Jun 14, 2009 | Sony BD Remote Control for Playstation 3
PS3 SCROLLS DOWN AND WONT SCROLL UP!!
i have face the the same problem with my ps2 conttroler. In my case it was the problem with the analog (the sticks). May be the spring of your left analog is broken is broken. Do not try to open it yourself and fix, it can disturb the wiring of the remote. Take it to your local ps repair shop or you will have to buy a new one
May 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 Controller will only work when plugged into the USB
I picked up the folling troubleshooting tips from the PlayStation Knowledge Center. I know it may seem silly or insulting; This is not my intention. Problems like this are usually just little things you're over-looking. Give thest tips a shot, one by one, and see if your solution is in here. If it isn't, message me back here & we'll try something else to get your controller working, ok? By the way... Is it a sixaxis controller or dualshock?
  • Verify if the SIXAXIS or DUALSHOCK 3 wireless controller works with the USB cable.
  • Verify that the SIXAXIS or DUALSHOCK 3 wireless controller's battery is charged.
  • Attempt to pair the SIXAXIS or DUALSHOCK 3 wireless controller to another PLAYSTATION 3 system. This helps determine whether the problem is with the system or the controller.
  • Attempt to connect another SIXAXIS or DUALSHOCK 3 wireless controller to the PLAYSTATION 3.
  • Move closer to the PLAYSTATION 3 system. The maximum range for Bluetooth is 30 feet.
  • Make sure you have less than seven Bluetooth peripherals paired with the PLAYSTATION 3.
  • Unplug any other USB device plugged into the system when pairing the SIXAXIS or DUALSHOCK 3 wireless controller.
May 19, 2009 | Sony Playstation 3 (PS3) Console
Sixaxis controller turns left
The solution is simply to buy a new controller, or get a cheaper one like 'madcats' or 'Logitech' which is about half the price of the SONY brand.
But you need to consider this if buying a brand other than SONY;
it might not last as long maybe about 6 months-a year before it gets funny with the controls. Also, most of them needs a USB receiver and batteries for the controller to use wirelessly for PS3. Which I think is troublesome, cause you can't charge it like the SONY dual shocks, and have to spend more money for new batteries or rechargables. You also need to sacrafice a USB slot on the PS3 for the receiver to work wirelessly with the controller, and I have no idea what the response is like when playing games, it might not play as smoothly as the original SONY Dual Shock.
May 01, 2009 | Video Game Consoles & Games
Video Game Consoles & Games Logo
21 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
