Question about Video Game Consoles & Games
Connected my ps3 to my Samsung LE32R74BD through the pc port using a HDfury connector but can't get a picture! I know the tv supports 720p and 1080i but all I get is "mode not supported". I even connected the ps3 to my pc monitor and set it to 720p, reconnected it to the Samsung and still no joy! Please help! Si
J4XXN
  • 182 Answers
SOURCE: 1080p 480p
if you hold down the power button when you turn it on for more than 4 seconds it runs the display setings and puts it in the best possible option
Posted on Jan 08, 2008
SOURCE: call of duty 4 1080p
First off, Sony doesn't make Aquos they make Brava. Sharp makes Aquos. Secondly, I am unable to uncheck 720p how do I do  this?
Posted on Jan 15, 2008
Randy V
  • 236 Answers
SOURCE: I moved my ps3 from
press and hold the power button for at least 5 seconds until you hear a 2nd beep.
this should reset your settings and the video/audio will autoconfigure if you have HDMI. if you have another type of connection, use the setting under video settings and adjust them to 720p.
Posted on Aug 30, 2008
Big Hev
  • 64 Answers
SOURCE: PS3 wont go 1080i/720p
I don't think there is a way to set your resolution manually, bro. They do it all by auto. If I may make a suggestion... Turn off both the TV & PS3. Unplug your HDMI, then make sure both your TV & PS3 are turned ON. Now re-connect your HDMI. A TV tech once told me that these units "communicate" through the HDMI. This can only occure whilst they're up & running. This may help get you going on to 1080i.
p.s. PS3 games only output 720p, max! This isn't always the case for Blu Ray movies, but it is for games. Good luck!
Posted on May 23, 2009
Midwest-Tek
  • 864 Answers
SOURCE: new ps3,new 40in. samsung 3d
To change this setting, you must exit the application and change your Video Output Settings from the display settings option in the Settings menu. Make sure the tv is not set on 720p/i and that it is set to 1080i. There has been issues with games that are 1080 downscaling the resolution. this can be confirmed by reading this article. if you provide me with the model of the tv. I can help assist you in ensuring its on 1080p. If you need further assistance please let me know after you try the following above. Thanks, Midwest-tek
Posted on Aug 28, 2010
Dynex HDTV says not supported when PS3 is connected via HDMI
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv size...select the size- now you need to set the resolution...select all resolutions that the TV supports, since it is a dynex...it is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Mar 21, 2014 | Video Game Consoles & Games
Ps3 wont work on my ln t3232h says not supported mode
Very easy fix guys. all you gotta do is use either your component cables or hook the ps3 up to a different TV than change you output settings from 1080 to 720p, thats the reason your not getting an image is the ps3 is set to a 1080i or 1080p output, but the tv is only capable up to 720p. good luck ^^
Jun 26, 2011 | Samsung LN-T3232H Television
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
New ps3,new 40in. samsung 3d led, new monster hdmis yet when i play god of war3 which is capable of 1080i it automatically gives me 720 not even 720p. so i unchecked 720p in setup and it gave me 1080 not...
Aug 28, 2010 | Sony Playstation 3 (PS3) Console
I have a Playstation 3/blu ray player and I don't know how to get hi def video on a samsung hln467w
Your TV only has a DVI input, not an HDMI which PS3 has as an output. You can buy a HDMI to DVI adapter and connect the HDMI out of the PS3 to the DVI input of the TV. To get the true HighDef video you need a HDMI input on the TV to enjoy the full capacity of the Blu ray capabilities of the PS3. DVI came out before the HDMI standard and your picture will look good but not like HDMI. I have the same problem with my samsung 65 inch. I Bought the wrong technology. I hope this helps and good luck!
Nov 07, 2009 | Samsung HLN467W 46" Rear Projection HDTV
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
4yr old Mitsubishi DL 52525, HDMI input vide problem
Are you sure its the TV and not the source? Are you sure its only the HDMI port on the TV? The only reason why you must HDMI is to get 1080p and your TV doesn't support 1080p. Its supports up to 1080i. Your TV has a native resolution of 720p which means it can accept a 720p image and not need to scale it, so the picture will look the best at 720p but will support 1080i. I would use component cables to connect your sources and set them to output 720p.
Mar 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Ps3 problem
Change the resolution on the ps3 to accept 480p, 720p, 1080i, 1080p.
Jun 14, 2008 | Sony Playstation 3 (PS3) Console
Time lag between Playstation 3 and LCD TV.
SOURCE: http://boardsus.playstation.com/playstation/board/message?board.id=confrontation&thread.id=735278&view=by_date_ascending&page=2
If your playing with lag on your new HD LCD your at a competitive disadvantage! Everything you see happens seconds later than your opponent who has his/her settings right.
The fix:
1. Connect your PS3 using HDMI Input 2.
2. SELECT or RENAME the HDMI Input to PC. Already pointed out, but this does not make the majority of tv's run in PC mode.
3. On the PS3 start-up menu go to Settings---> Display ---->
Choose HDMI ----> DO NOT choose AUTOMATIC ----> SELECT CUSTOM ----->
4. Now, Select all the Resolution options EXCEPT 720p. This will force your games into 1080p mode. What it will also do is drop any game that doesn't have 1080i/p support into 480. Games like Burnout Paradise, Vegas 2, Heavenly Sword, NHL 08 and more will be dropped into SD (480) rather than HD. Your picture will be terrible. 720p is standard gaming resolution currently, 1080i/p is not.
5. Save and complete the display setup.
6. Turn off the PS3. Turn off the TV.
7. Turn on the TV. Turn on the PS3.
8. Complete! (Lag eliminated). Please spread this around!
*The key to eliminating ALL LAG is modern LCD's need to be in PC MODE (NOT GAME MODE) On many tv's, PC mode requires you to use a VGA or DVI connector. You'll either need to buy an HDMI adapter or an HDMI to VGA / DVI cable if that's the case.
and the Source MUST BE IN 1080p so that the TV can use it's NATIVE RESOLUTION.* Please, check your tv's native resolution. If you have a plasma that only does 720p, your native resolution is probably 720p. You do not need to follow these steps, it will only make things worse. If your tv's native resolution is 720p, obviously you want to keep your display settings at 720p on your PS3. If your native resolution is 1080i, you shouldn't go selecting 1080p. If your native resolution is 1080p on your TV, you need to be aware that removing 720p as an option will force many games into 480.
Keep these things in mind and remember that the steps above are far from a cure all solution. .
Lag gone! Worked for me! (SAMSUNG LNA52850)
Source : http://answers.yahoo.com/question/index?qid=20081225141902AApX7cJ
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Ps3 trouble
ok, i got it working... Ok...your problem is probably that when you're using it on the HDTV...you have the resolution set to an HD one (720p, 1080i, 1080P). A normal TV cannot display these. While it's connected to the HDTV,Before you connect it to your normal tv, you have to switch it back to 480i or 480p otherwise, your regular tv wont show a picture. So go to settings, display settings, and uncheck 720p, 1080i, 1080p. It will ask you if these are the settings you choose (and it's going to look funny on your HDTV) Accept the settings and turn it off. When you connect it to your Regular TV, you should now see a picture. Hope this helps!
Dec 13, 2007 | ViewSonic N2060w 20 in. LCD Television
Video Game Consoles & Games Logo
64 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
