Question about Cardiozone Supersport Hr Club Commercial Treadmill
My cardiozone treadmill will countdown for 3 sec, then start, run for 7 sec, and stop, showing error code E1. I have cleaned and lubricated, checked that all of the wires thru the handles and control board are still connected, checked the lights in the base (which are green). What else is there?
  • 33 Answers
Your problem might be that a magnet has fallen off. Here's an illustrated guide which should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
Merit 725 T plus reading E1
If you wish to get some details about treadmill error codes and repair; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 28, 2016 | Exercise & Fitness
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
E1 error code
This usually means a faulty LCB or motor.The fact it has not been used much doesn't matter. It is 7 years old. Usually you can not see faulty parts on the LCB. I do think if you really want the answer call a treadmill repairer . If you don't know what you are doing it can be dangerous.
Dec 03, 2013 | Cardiozone Supersport Hr Club Commercial...
Carl lewis mot566 treadmill error code e03
please adjust the REED switch, see the diagram attached. Clean it +test it for open or faulty+tight the connector very well.
However if the problem persist error code 3, this is a problem with the PCA memory location, RAM. the solution is to replace the PCA.
Try to RUN the software calibration for easy diagnostic, and fix it
God bless you
Jun 22, 2013 | Exercise & Fitness
CardioZone SuperSportHR Club Fold-Away II ERROR 1
see the video and proceed according. God bless you
2) LUBE the rollers bearings too
3) test the drive belt motor, and replace it
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for help
5) Test the output voltage board, for input voltage motor, if there are NOT THE board is faulty. see the block d.
God bless you
Nov 29, 2012 | Cardiozone Supersport Hr Club Commercial...
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 28, 2012 | Kettler treadmill Pacer
Cardiozone Club HR T Error Code SI2
see the details and fix it. God bless you
Error - "SI2 At Power Up"
Symptom:
Indicates the OVP (Over Voltage Protection) circuit on the controller is active and belt will not move.
Solutions:
  • Check for RAIL and LVS LED's to be lit.
    • RAIL and LVS ok? Replace F2 fuse
    • RAIL not lit, but LVS ok? Replace F1 fuse
Nov 17, 2012 | Exercise & Fitness
I have an E1 error on my Cardiozone Light commercial fast track elite 2 treadmill
1) adjust the speed sensor, and clean it, and tight the connector very well.see the diagram
2) test the main board output , for input voltage motor, if there are NOT the board is faulty see the block.
3) test the motor for input voltage, if there are the motor is faulty
God blesss you
Sep 19, 2012 | Exercise & Fitness
E1 error code
Lets eliminate the motor first, unplug unit remove motor shroud fin the 2 leads from motor to lower board. Connect a 18v DC battery to the leads this start the motor to move at approx. 1 mph if it does motor is good,if not you may worn motor brushes worst case open connection in the motor.
Now if the motor is good then reconnection the leads and plug in unit the lower board should have some LEDs lit up. Now find the LED that says PWM start unit if that light should start to flicker then the upper board and wire harness are work properly. Turn off the treadmill then turn it on and with a multi meter insert the leads into the connectors that go to the motor, then put the meter on 200v DC then start the treadmill you should get a reading 5 to 10v DC if you get 0v DC then the board will need replacing
Jul 07, 2010 | Cardiozone Supersport Hr Club Commercial...
Model :ion treadmill 7.9t (bladez ) ,e1 error runs 7 sec and stop
E1 represents a speed sensor error. Remove the cover and the speed sensor is located alongside the top left roller/wheel. this wheel has a metal disk on it's side that the sensor counts each time it passes. Adjust the sensor as close to the metal disk as possible without making physical contact. Roll the wheel several times to ensure there is no contact. It was noticed on ours that the alignment of the sensor is not centered to the metal disk, and was reading the outside edge of the disk. Turn the sensor just a bit to read as musch of the disk as possible.
Jan 03, 2010 | Blaze Exercise & Fitness
Cardiozone Supersport Hr Club Commercial Treadmill Logo
795 people viewed this question
Top Cardiozone Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Cardiozone Exercise and Fitnes Expert? Answer questions, earn points and help others
