Question about GE Profile PDW8400J Built-in Dishwasher
My GE Profile PDW8480J01SS doesn't dry the top rack, even though the detergent packs I use have rinse agent. help!!! there is also a white residue on the glasses when I am hand-drying them.
  • GE Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on May 01, 2011
Dishwasher is going on 3.5 yrs old, it worked well for the 1st year but for the last year & half it has been leaving gritty residue on all the dishes. To the point, dishes are being hand washed to...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101//
Mar 22, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Tip
General Dishwasher cleaning
There are 3 types of energy used to clean the dishes a balance of all three are needed for the best results.
Chemical Energy - The detergent you use plays a big role in the cleaning ability. Phosphates do a great job but as new regulations come into play phosphates are being phased out. Detergent can get 'old' and loose it's cleaning ability. It has a short life span, so buy detergent in small quantities. If you have hard water you will need to use more detergent or even an additive like lemi shine or Glass Magic to assist with the chemical energy. Detergents for automatic dishwashers have a no sudsing agent to reduce foam and suds. Rinse aid plays an important role in eliminating spots and drying the dishes, yes drying. The rinse agent helps sheet the water off the dishware prior to the dry cycle, there is a product called Turbo Dry that can be used in place of rinse agent that works great for drying plastic. In summary use detergent like Cascade or Electrosol and a rinse aid
Thermal Energy - Hot water is important for both dissolving/activating detergent and breaking down food residue so it can come clean from the dishware. It will help to run the hot water faucet at the kitchen sink until hot before starting a cycle in the dishwasher. If cleaning is a problem use the Pots and pans or High Temp wash
Mechanical Energy - This is done by water pressure against the dishware, be sure to load properly, do not stack or shadow other dishware, be aware of where the spray arms on your dishwasher and make sure you do not block them when loading. If you have a filter in the unit, clean it often, if you do not you may still need to clean out the sump on occasion. The spray arms may get food or deposits in the small jets (holes) that the water needs to come out. Inspect and clean as needed.
Links to other dishwasher tips:
Poor cleaning on upper rack Whirlpool KitchenAid or Kenmore
Clean light blinking flashing 7 times
Calcium white powder build up hard water
on Apr 25, 2010 | Dishwashers
The glass ware on the top rack is not coming our clear but rather with a blurry appearance. I have added the rinse agent on the door to no avail. Is the rinse cap supposed to be tightened all the way or...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Feb 21, 2011 | Dishwashers
A crusty residue settles on glasses and cups in upper rack and is extremely difficult to get off, requiring much soaking and scrubbing in hand washing, even when everything was prewashed going in! I've...
heatman101
Dec 28, 2010 | Asko 24 in. D3250 Built-in Dishwasher
I bought this dishwasher 2 weeks ago. The dishes are not always clean, the glasses on the top rack have a residue that gets dried on (white/gritty) and the glasses have a white film on them. I have...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Nov 06, 2010 | Viking VDB450 Dishwasher
Food residue left behind on my dishes on the top rack. The addition of a rinse agent doesn't seem to help. Suggestions?
heatman101
Oct 17, 2010 | GE Nautilus 24" Built-in Dishwasher
The items on the top rack never come out clean. there is always food residue left. it seems that the final rinse doesn't get to the glasses. we need to rinse them all out before the drying cycle starts...
heatman101
Jan 04, 2010 | Amana 24 in. ADB2500AW Built-in Dishwasher
I have a GE, PDW8600 Series, problem is - no matter how I arrange dishes the top rack always has deposits left on dishes that are on the top rack. The water is plenty hot.
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you're using and adjusting your hot water heater's water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
GA_googleFillSlot("HT_Appliances_Dishwashers_Articles_Box_Top_Left_ATF_300x250");
First you'll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, you can wash the glass with warm water and concentrated dishwasher detergent or use a high-phosphate detergent (such as Glass Magic) according to label directions.
If film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature. For more, see "Dishwasher Doesn't Wash Well."
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn't anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don't use extra-hot settings, such as "Power Scrub," and use the "Energy Saver" dry cycle.
2) Adjust detergent amount.
3) Don't pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
More about dishwasher problems & repairs:
Apr 20, 2009 | GE Profile PDW8600J Built-in Dishwasher
TOP RACK DOESN'T RINSE
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dirt and residue left on glasses
wash glases alone ad a jet dry aditive to detergant  Vitally
Jan 26, 2009 | GE Profile PDW8600J Built-in Dishwasher
GE Profile PDW8400J Built-in Dishwasher Logo
136 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
