Question about Kenmore 23822 Top Load Washer
I have a kenmore elite top load king size wahingmachine it fills with water but when the aggitation cycle should start it just Humms / buzzes like a motor is not turning If I increase the load size knob from med to large it wil add more water but stil will not turn. just humms.
  • 176 Answers
Cheng the baord
Posted on Aug 23, 2010
Kenmore Elite HE4T standing water
I also have standing water after a wash cycle, but not immediately after. Given the history of very expensive repairs to this Kenmore HE4T washing machine, I suggest you do what I do, if the machine is still cleaning the clothes. Whatever cycle you use, try to be around when the machine finishes, so that you can turn off the water supply and remove the damp clothes to the dryer or clothes line. Turn on the water supply only when you want to use the machine. This works for me because I don't do many loads per week and my laundry area is right next to my kitchen. If it was in my basement, I'd have replaced it already with a top loading machine with mechanical not electronic controls.
Aug 21, 2012 | Kenmore HE4t 3.8 Cu. Ft. King Size...
My Kenmore Elite washer will not fill.
yes there is a water inlet valve . it is the blue valve your water hoses connect to on the rear of the washer, they get sediment built up inside and get stuck , cost $26.50 from Repairclinic.com just go to site .find parts,then type in your model#
Jan 21, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
29522800 Kenmore Won't wash.
ouch def get a new one or get warranty to come out could be bad news
Jun 26, 2009 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Tub won't fill with water
You have a bad inlet valve. The valve is behind the hoses, you cant get to it one of two ways. Either through the top by removing the knobs and screws and face plate. or by removing the panel behind the hose
Feb 09, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Oct 30, 2006 | Kenmore 15944 Top Load Washer
Kenmore 23822 Top Load Washer Logo
99 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
