Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
I HAVE A RAYPAK 265A COD SAYS RV1 - Raypak Free Hydraulic Lift Gate Delivery - No L...
How to replace thetmal fuse raypak 265a
roll out switch bottom white piece screwed to front wall with 2 wires to it if it blew check gas pressure maybe overheated
Jun 10, 2014 | Raypak Pool & Spa
RAYPACK POOL HEATER CODE RV1 THEN SNS
check gas pressure and safety circuit then ignitor sns means temp sensor bad
May 31, 2011 | Raypak Free Hydraulic Lift Gate Delivery -...
Just opened the pool for the season. Heater not working. Screen shows RV1 and SSN (i think this is correct). Any suggestions??
I had the same problem I took the front cover off and used a wench to take off the gas jets they were filled with spider nests I cleaned each one out wit a large paper clip and put them back on and it worked
May 23, 2011 | Raypak RP2100 DIGITAL POOL HEATER R265
Raypak 2100 265A displays GVO. I know it means Gas Valve Open, but I do not know what is wrong. It is a IID Electronic Pilot. I see a slight flame when the igniter lights and then the system goes into GVO...
Here is the directions from raypak on this code.
1. Turn off power and disconnect ignition wire and gas valve wires from cpu board.
2. Turn on the power and watch for spark at module.
3. If no spark is observed, turn off power and replace the board.
4. If spark is observed, turn off power and reconnect gas valve and ignition wire.
5. Turn on power and unit should fire.
if unit does not fire and code reappears, turn off power and disconnect gas valve wires from the board and remove MV,PV and ground wires from the gas valve. Clean and reconnect wires.
7.Plug the gas valve back into the board and torn power on. Unit should fire.
8. If the unit fails to fire, Replace the gas valve.
Its not a good code to get. Hope this helps
Mar 21, 2011 | Rheem Pool & Spa
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
317 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
