Question about Homelite Mighty Lite Lawn Trimmer
Homelite 25cc model UT20002A. How to repalce starter string?
  • Homelite Master
  • 885 Answers
Remove the shaft assembly at the motor, there should be one or two screws on the boom clamp. Remove the four screws holding the starter housing on. Inside the front of the housing is an air baffle you don't have to remove and the starter pulley. Remove it carefully, you don't want the spring to come out of its container. Remove any vestiges of the old starter rope and install the new one with no more than three or four windings depending on the thickness of the rope you bought. Install the pulley in the housing with the rope through the slot in the pulley so you can wind it a couple times to catch the spring and start the tension. It should be tight enough to just pull the string back into the housing. Feed the rope through the hole in the housing then through the t-handle and tie a knot so it won't pull back through the handle. Put the housing on the motor, no screws yet, and pull the rope out to make sure nothing is binding and the rope retracts fully into the housing. If it's too tight use the slot in the pulley to take one winding out. If the t-handle dangles, add a turn to the pulley. Reassemble housing and boom and you're ready to go.
Posted on Aug 23, 2010
How do I change champion strimmer cord
this is the pdf user manual for it
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfChampion Strimmer Manual - 64.140.158.30 homelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s manual your manual ...
Jul 17, 2016 | Garden
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
Was given a homelite zipstart versatool string trimmer (25cc). what is the proper gas to oil ratio for this tool?
between 32:1 and 50:1 should be OK.
The best bet is to buy the premeasured 2 cycle fuel/oil mix in the bottles. They come with 8oz for a gallon of fuel.
Sep 23, 2009 | Garden
Starts but when throttled continues to die
You have carburetor problems. You will need to take the carb. off and disassemble. Clean the carb. with carb. cleaner and use a Den Tek Brush, (used for cleaning teeth), for the small portals. Check the small screen in carb. to make sure it isn't clogged. The smallest of particals can cause the carb. problems. Check the gaskets as well. Depending on how old your trimmer is, you may have to buy a carb. kit and replace the Needle valve, appropriate gaskets, diaphragm, and small screen.
Jim
May 30, 2009 | Homelite Garden
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Loss power Trimmer HomeLite UT20002A
Check the muffler for obstructions. Remove the muffler and check the exhaust port sometimes they are near plugged. If so remove all the crud with the cylinder in up position to prevent getting carbon in cylinder. Trimm to adjust Turn both L and H set screws clockwise until they bottom the back each one out 1 and 1/4 turn. This should allow you to start the trimmer. Then rev to max rpm and adj. the H screw to max rpm. Then set the idle with the L screw with good idle without string head turning. Then when throttled it should do so without hesitation. Once this is set you may have to fine trim the H screw for max rpm again.
Mar 12, 2008 | Washing Machines
Homelite Mighty Lite Lawn Trimmer  Logo
199 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
