Question about Brother XL-2600
My machine is only sewing backwards, it seems to only sew backwards. I was using the reverse button but when i released it the machine was still sewing in reverse. can you nhelp
  • 109 Answers
Try hitting the reverse button twice in quick succession. SOME machines have a permanent reverse feature. Also check your manual for this feature.
Posted on Aug 23, 2010
Machine will only sew in reverse
You wrote,
"Machine will only sew in reverse - Sewing Machines" A: I'm just a tinkerer, hobbyist, who did run across this same problem before. I can give a general non-model specific remedy based on my limited experience with mechanical sewing machines that get locked into sewing backwards, that is "they only want to sew in Reverse":
1. Verify what is the normal direction of the fly wheel in forward sewing for your machine. Most sewing machines, including Singers, always sew with the top of the flywheel moving toward the operator, regardless if sewing forward or backwards; but older friction-wheel White Rotary (RF) sewing machines, have the flywheel running in the opposite direction (top of Hand-Wheel turning away from the operator when sewing.
2. If it has Reverse Lever/Switch; check that it is in the correct position; if still only sews in reverse, change positions of the Direction Control lever (or Button, etc.), and see if it changes direction to correct the problem.
3. If this does not help, then jiggle the Reverse Lever and follow the linkage inside the machine and see if there is anything broken, loose or out of adjustment. Some machines have reverse control linkage elbows in the top part of machine, and by poor design are prone to accidentally pop backwards, causing sewing in the opposite direction of the position of the Reverse Lever/Button (Backwards when you want to sew Forward). On occasion, a Kenmore 158.1787180 got locked into the backwards sewing mode (the dog-gone' est thing), but by following and analyzing the linkage, I found where it was going wrong, and popped the indecisive linkage elbow back the way it was supposed to be and fixed it. [ I had more detailed notes, on this fix, but when I read them, without the machine in front of me, made no sense to me today so I can't share that till I revisit the conundrum again.]
4. If all else fails, you may be able to hold or clamp the Reverse Lever/Button in the Reverse position, so it sews Forward (I've done this before too (as a short-term fix) until I figured out how to adjust it back the way it was supposed to be.
5. If this post helped you, don't be afraid to indicate so, so Fixya will know. If it was useless, "ouch", but I'd like to know that too, so I'll be more selective on what I really know more about. I try to help, though this is probably a trade secret that anyone who knows is discrete about who they share the information with.
Sincerely
-- Amender. (2016 FEB 24)
Feb 06, 2016 | Sewing Machines
Can't remember how to stop sewing backwards
a small button or lever makes it reverse
Dec 04, 2015 | Sewing Machines
SINGER TOUCH N SEW 771
Use the wheel at side of machine and gently push back and forth it should release reverse lever
Mar 04, 2015 | Singer Sewing Machines
My sewing machines reverse sewing botton seems to be broken
You should call Singer Consumer Affairs at 800-474-6437 or email them at talktous@svpworldwide.com.
Jan 19, 2010 | Singer 3116 Simple
Brother Machine!
The reverse mechanism is stuck. The machine has to be completely disassembled to get to the problem. It is usually not a big deal to get it "unstuck" but taking it apart can be a pain. A good machine tech. can do it easily or you can give it a shot. Just look what the reverse lever actuates and see how it is stuck in the reverse position. It is usually the stitch length/reverse block.
Aug 06, 2009 | Brother XR-65t Mechanical Sewing Machine
I own a Sears Kenmore machine that began sewing backwards
Make sure that the reverse button isn't stuck inside. if all else fails, go back to sears and have them look at it.
Jul 02, 2009 | Brother XR-65t Mechanical Sewing Machine
Husqvarna Viking Sewing Machine 6020 sews in reverse
It doesn't need a part for this repair. The reverse mechanism inside the machine is seized from old grease which has hardened. It should be seen by a technician so the part can be cleaned out. Don't be surprised if he finds a broken take up slide or a cracked pattern mechanism.
Get an estimate before you have any work done and ask about a warranty for the work they plan to do.It may be less expensive to buy a newer machine.
sewman7
May 02, 2009 | Husqvarna Viking 1
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Brother XL-2600 Logo
441 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
