Question about Kodak EASYSHARE M1063 Digital Camera
When I turn on camera flash opens and then closes right away.
  • 25 Answers
  1. If any accessory devices (memory card, lens, USB cable, camera or printer dock, etc.) are connected to your camera, disconnect them.
  2. If your camera is on, turn it off.IMPORTANT: Verify that the battery/batteries are installed correctly.
  3. Install a new or fully charged battery/batteries into your camera.
  4. Turn on your camera.
  5. Set the flash to When I turn on camera - iconfillflash.gif.
  6. Take a picture.
Posted on Aug 23, 2010
My camra opens, then closes stright away without turning on. The battery is charged and the memory is not full. what can it be? and how would i fix it?
It is possible that when you camera starts up the processor is checking for all inputs. It is however getting some wrong information as errors and requesting for the shut down. Is is possible that there is a jammed shutter/cover. possible short in the electronics, in the flash unit or the lcd drive. Opening a camera and checking for the voltage details may require some experience and you can attempt this only if you think so to open with the right tool and check for the voltage drop on start up. Disconnect and trace to isolate the fault area. Otherwise seek help but make sure that the estimate is low and explained to you. Good day
Aug 10, 2010 | Pentax Optio M50 Digital Camera
I have loved this camera but everytime I take a flash picture it causes the subjects to close their eyes. I've never had this problem with other cameras. Is the flash not timed properly or is it too...
Are you using the red-eye setting? An initial flash causes the pupils of your subjects to contract, followed by a second full flash 1 second later.
The trouble is that the first flash is bright, and subjects think its all over so they blink, rub their eyes, look away, and even the photographer may be pointing the camera elesewhere by then.
It is better not to use that setting, and fix the red eye afterwards.
With the flash open, hit the right button until the eye icon goes away.
Dec 12, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
Z740 cannot focus on long-distance indoor shots
Have you tried changing the mode? ie portrait, closeup, macro etc?
Jun 19, 2009 | Kodak EasyShare Z740 Digital Camera
Lens stuck, green Power light flashes, nothing happens.
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time  you will hear a clicking noise which is normal  once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Dec 08, 2008 | Samsung Digimax S500 Digital Camera
Kyocera Mita KM 1500
Still sounds like there is a problem with the fuser unit. The technician that replaced the parts should be able to troubleshoot the problem.
C6 = Fuser error. The unit is not heating up due to a bad Fuser lamp, fuse, or thermostat, or bad thermistor.
The circuit is open, and the machine won't work til the problem is repaired. Once open circuit is repaired/closed, the machine should reset on it's own after you power the machine down and back up.
Does the machine flash the C6 right away as soon as you turn it on OR, does the C6 show up after about 3-5 minutes?
If you get the C6 right away, then the circuit is open, and that needs to be fixed.
If you get a c6 after 3-5 minutes, then there is a good chance the lamp is bad.
Hope this helps.
Good luck
Feb 08, 2008 | Video Cameras
Battery problem
did you use comapny authorised battery if not go for it
Apr 24, 2007 | Canon PowerShot S1 IS Digital Camera
Flash wont work
this is probably because you either have it on close up reang (the button on the top/side or your out of battery
Feb 27, 2007 | DXG Technology DXG-506V DV Digital...
My picture is blurry or out of focus.
ake sure your subject is within the camera's range. You should be at least 20 inches away to take a picture without the flash, and 20 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close-ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. See Chapter 4 for more information about how to change the shutter speed from the LCD menus. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Picture blurry or out of focus.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 750Z Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
