Question about Faema FA60081
Need service. one wond doesnt work. it brews too fast espresso is bitter. having a hard time finding a repair service in auburn, alabama. can u help?
    Problem Solver:
  • 23 Answers
Hi Swim 410 Try grinding the coffee beans finer this way the coffee will come out with a creme on top & not watery.
Posted on Apr 18, 2012
    President:
  • 1,618 Answers
I might be able to help you repair it. First I need the model of the machine is it a DUE/A or a Special 87. Next check the steam wand tip to make sure it is not blocked, if not blocked, you might have to remove the top panel, if it is a due there are 8 screws on the top if it is a special 87 there might only be 4 or a series of panels. Turn off machine and disconnect from power. Then follow pipe from steam valve to boiler, remove the pipe you will notice blockage either in the pipe or at the boiler fitting, clear blockage. For the group heads I would check the screens make sure there is no damage, and check the grind on the coffee grinder that might be too coarse.
Posted on Aug 24, 2010
How can I avoid bitter coffee?
If the water that comes into contact with the coffee grounds is too hot, you will extract bitter elements from the coffee. The water should not be boiling when poured on the coffee grounds. Coffee oils, fats and sediment are the natural parts of the coffee bean that causes bitterness by forming as the brew ages. The longer the coffee sits the stronger it tastes.
Article Source :
Espresso Machines Coffee Makers Grinders Reviews
Sep 08, 2014 | Coffee Makers & Espresso Machines
Bitter taste
You will likely find the bitterness is a function of your coffee bean choice or the 'roast' component of that coffee. Darker roasts tend to taste bitter.
Nov 03, 2013 | Cuisinart Grind and Brew 10 Cup Coffee...
Why are some coffee's more bitter than others?
There are several factors resulting in a bitterer cup of coffee:
The bean - Robusta beans are more bitter than Arabica
Roasting - darker roasts are generally more bitter
Brewing method - espresso tends to taste more bitter
Feb 07, 2013 | Wine & Spirits
My coffee tastes watery. It seems as though the water flowing through the filter is going too fast. My other Keurig at work brews much slower, and the coffee is delicious.
Hi, Your coffee is ground too coarse. Make the grind finer as this will slow down the flow rate. If you go too fine it will just dribble and over extract the coffee."bitter". Dazza REPAIRER
Sep 23, 2011 | Keurig B60 Coffee Maker
Brew temperature is too low
I think you ment kaffeestudio.de and their webshop redirects to
http://www.juraprofi.de/Service-Anleitungen:_:70.html
Eg http://www.juraprofi.de/anleitungen/E-Serie_Innen.pdf
May 31, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
My Bunn is taking forever to brew and the coffee
It sounds like the thermostat might be allowing the water to boil and cause the grounds to be scorched and making your coffee bitter. It also could be caused by the machine needing to be cleaned and delimed. I would recommend you do this first-and if you don't have the use and care manual, you may call Customer Service to have one sent out or access one at www.bunn.com @ home, then products.
Apr 09, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Baby Gaggia making a bitter brew, help!
Have you tried backwashing, then removing the shower and screen from the grouphead to make sure that there is no coffee buildup on the screen.
As for the leak around the portafilter, the group gasket needs to be replaced,
Jul 02, 2009 | Saeco Classico Espresso Machine
Steam still coming through brew group even when pump not ON
I posted response and solution to similar issue see post below and comments :
YOU NEED TO LET MACHINE COOL OFF AFTER YOU TURN IT OFF OUCH!!
You can release pressure placing a cup under steam wand open slowly and partially while machine is OFF and let hiss out slowly. Then open cup slowly if you have to force it open DON'T. That PUCK sound can make you afraid of your machine can't it. I wont admit I haven't done that four or five times.
posted by bronwenmair on Jul 08, 2008 Report abuse
We have a Saeco Classico that worked very well when we first got the machine. Now the coffee is bitter and there is no crema in the shot at all. We tried changing grinds and tamping, nothing seems to work. Can you help? Thanks so much. We miss our morning coffee :-)
Jan 20, 2009 | Saeco Classico Espresso Machine
Coffee Makers & Espresso Machines Logo
113 people viewed this question
Top Faema Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
