Casio (41644) 2.3 in. Handheld Television Logo
Posted on Aug 23, 2010
I have a Casio tv-995and I can't figure out where the batteries go, or how to open it.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
420
Points
It opens directly below thw LCD screen. Push in and slide down, where the 4 dots are below the screen. It opens from the front.
Where/how do I open the part for replacing batteries?
Seems you replace the batteries on the front bottom of the unit or the back. If you do change the batteries you may not be able to use it as most is digital nowadays. Unless you have a analog station near by you won't pick anything up.
Restarting a Casio 4735 after battery change
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
this video is only an example as to what to do hope this helps you..
http://www.youtube.com/watch?v=ogCz2vjUKVg
2helpful
How to restart my casio module no 2271 watch
mcdevito75 here, I'm figureing you"ve changed the battery, Pressing the MODE button should re-start your watch. If you didn"t change the battery and your watch just stopped, try pressing the MODE or any button to re-start the watch. If nothing, change the battery and repeat the above instructions.
Have a casio g-shock GS-300. Need to turn off the hourly signal (the beep). Grateful for solution
I have a Casio GS-300 watch. I need to change the batteries, but cannot figure out how to get the back off. Do you have any ideas as to how I can do this.
Thank you Vanessa
3helpful
3answers
Casio module 2273 battery change
did u ever figure out how to get the retaining clip?
I can't get my CASIO model TV 995B open to replace the batteries.
hold the tv with the front facing the top; then under the tuning buttons you should be able to push and slide down the bottom of the tv.. if i had a bigger picture of what yours look like then i could help more. or even go to casio.com and get manual for it.
4helpful
New battery can not reset watch CASIO #2735 Atomic wave ceptor
Did you try this?:
http://world.casio.com/wat/download/en/manual/
Rate, please.
1helpful
Casio Altimeter watch, no instructions
I was just gifted an old casio pathfinder model 1675 with the manual.
when inserting a new battery.....step #4
AC (AC CLEAR) touch the AC contact and the battery +(positive) side with metal tweezers for about two seconds.
Contacting the AC (all clear)is necessary when a new battery is installed to clear the previous memory to avoid erratic display..
I am going to get a new battery for it soon I want to play with it....and figure out how navigate through the functions.
oh yah......the pictures are extremly small but the AC contact point is apparently marked? inside the case obviously next to the battery close enough for the needle nose tweezers to reach each contact. I havent unscrewed my case yet, I want to have everything I need at hand like the battery before I dive into this thing. I dont mean to dumb it down, I was trying to keep it simple as the manual is 55 pages and a little confusing. I hope this helps the battery problem. I will try to delve into the reset problem from the other post..each function appears to have a reset option ......maybe crack the case open and try the new battery all clear thing with tweezers...maybe this would reboot so to speak the entire watch , being mine does not work and have only had it in hand for two hours I am pretty clueless, I was looking for how much the watch costs...i didnt relize it was a fairly old model, the new ones with the compass look very cool. anyhow goodluck
1helpful
3answers
Casio watch
Get the code from the back of your watch and try going to the casio site for the manual. http://world.casio.com/wat/download/en/manual/ I was reminded of this by Noggins posts No if I could only figure out how to change the battery
Top Casio Televison & Video Experts
Johnny 1000
Ngoro
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
