Question about Maytag M7DH45B2A Dehumidifier
Running but not taking water out of room. - Maytag M7DH45B2A Dehumidifier
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Sep 09, 2010
My dehumidifier sh3030 is not collecting water but is running fine
You say it's running "ok", but there is no water discharge. If that is true then you have absolutely no moisture in your air and that is practically impossible. So we can say effectively that it is NOT running "ok". Fell the discharge air from the unit. If it is roughly room temperature rather than substantially warmer that than the air in the room, then you have found a problem. That problem would be that while the fan may be running, the compressor that heats that air and gets the condensation going is not. If you feel little or no air from the discharge, then you could have a clogged coil or filter (you checked that), or a bad fan.
Dec 11, 2016 | Dehumidifiers
What settings need to be on to take water out of the air
There is usually 3 choices
As long as you hear the fan come on
& the compressor cycle, it is working
See no reason you can't try the features on the
control panel
They pretty much tell you what they are for
May 11, 2014 | Danby DDR600R Silhouette Dehumidifier
THIS UNIT IS ABOUT A YEAR OLD, IT RUNS, FAN BLOWS AIR OUT THE SIDE, BUT IT JUST RUNS AND RUNDS. HUMIDITY IN ROOM IS UP AT 75 AND IS SET AT 30. THIS DID WORK FINE WHEN NEW IN ROOM. IS THERE ANYTHING I CAN...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Aug 15, 2011 | Frigidaire FAD504TDD Dehumidifier
Dehumidifier makes the room too hot where it is running. does very good removing water need too empty 50 pt every 24-30 hrs.
The dehumidifier does not heat or cool, but the compressor running will produce some heat and it can make a room hotter...
heatman101
Aug 29, 2010 | GE AHG40LJ Dehumidifier
My dehumidifier runs but isnt taking on any water in a very humid room. i cleaned the filter and i am still having this issue. do you have any possible ideas?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
May 29, 2010 | Frigidaire FDL45P1 Dehumidifier
The dehumidifier is running but no water is in the bucket. Should the setting be on low humidity because that is what I want or should it be on high because that is what I want to take out of the air?
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 05, 2010 | Haier HD656E Dehumidifier
Why would it not take water out of the air, it runs so long it creates ice on the outside of it. With no water in the bucket. its in the Basement its 52 degrees and the humidie is 84. what can i do to...
Room must be above 60.
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 28, 2009 | Whirlpool AD50J Dehumidifier
AFTER RUNNING CONTINOUSLY, THERE IS NO WATER IN THE BUCKET
What is the dry bulb temp in the room? what is the wet bulb temp in the room? what are you working in temp (in room)
Jun 08, 2009 | LG LD40E Dehumidifier
Kenmore dehumidifier is running but not pulling water
normally this means that the compressor is not running. Check capacitor and connections to compressor.
David
May 25, 2009 | Kenmore 53701 Dehumidifier
The dehumidifier is running but very little water is going into the tank. I cleaned the filter, long overdue, and it didn't help. Everything seems to be running well. I also have the room humidity level...
I have the same problem, just started it after not using it for the winter and it runs and runs and no water. I believe the coolant has leaked from the sealed system and there is nothing you can do. I've had it for 1 year and it has a 5 year warranty. I know from experience, this is the 3rd dehumidifier that I have had this problem with, all different brands. Call for service, I am betting you have not had it very long.
May 07, 2009 | Fedders A7DH45B2A Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
