Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Door hinge springs broken...how to fix myself?
  • 530 Answers
Very easy but you have to slide it out
you need the door links part number 1059756 you can go to repairclinic.com to get them
to the left and right you will see a metal spring with a rope attached to it. the rope is what always breaks
when you get the new peices make sure and install the whole kit because it is a upgrade.
Posted on Aug 23, 2010
Testimonial: "Thanks! Will do!"
How do i fix a broken spring on a dishwasher door
You will need to pull the dishwasher out about 12" to 18" to be able to get to the springs & rope links. Many dishwashers use a "rope link" to connect between the spring and the door hinge; and in others, the door springs connect directly to the door hinges. Once you pull the dishwasher out, you will easily see what broke and what you need to fixe it.
Jan 20, 2015 | Frigidaire Dishwashers
The dishwasher door spring has snapped, the door is heavy, can I fix it myself?
Yes, you can repair the unit yourself. It will require removing the dishwasher out of the cabinetry to get to the spring cable. The spring is not the problem but the connector between the door hinge and the spring is broken.
The part you need is 4933DD3001B. You will need 2 of them.
Hope this helps.
Oct 29, 2011 | LG LDF6810ST Stainless Steel Built-in...
I have a dishlex 300 and when i open the door it just drops down could this be something with the spring or hinges in the door
tHE DOOR SPRINGS ARE BROKEN. IF YOU HAVE DROPPED THE DOOR TOO MANY TIMES THE HINGES MIGHT BE BENT TOO. yOU WILL PROBABLY NEED HINGES AND SPRINGS....A bit of a job for a novice....like my capitals sorry about that.......
Mar 01, 2011 | Dishwashers
My KRUPS FBC2 glass door hinge is broken. We use a pan to keep door in place when using it so it doesn't fall down. Any ideas on how to fix it will be appreciated. I'm pretty handy with things but I just...
I just fixed the problem with my Krups FBC-212. The door would not stay closed because the spring that keeps it in the closed position was broken. I ordered another from one of the small appliances parts sites (about $7 plus shipping) and that fixed it. I will describe how to do it and how to avoid the mistake that made it much harder and longer than it should have.
Remove the black screws at the back side, the ones holding the external black metal case to the silver chassis. There are 9 of these on my oven.
Also remove the 3 screws holding the left-side foot on.
Now you can probably slide the metal case (previously held on by the 9 screws) out from under the black metal front frame on the left side, thereby exposing the broken spring.
If you cannot get it out from under the lip of the front frame, you can take off the right-hand foot, and if that is not enough, you can remove THREE of the 4 black screws just inside the door holding the front frame to the chassis. Do NOT remove the lower left one next to where the flat door hinge piece goes into oven (which was my mistake) because that screw holds a critical black plastic piece in place.
By now you will be able to slide the black case that covers the sides and top backward and outward enough to expose the broken spring. It will be obvious how to attach the new one.
Aug 28, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
Passenger door hinge spring mechanism is broken 97 gmc jimmy
The spring is likely "broken" because the pins in the bushings are worn. It's a common failure point on many GM vehicles. The hinge pins, bushings door check roller and spring can be replaced at most body shops for about $150-200.
Apr 23, 2010 | 1997 GMC Jimmy
I have a Kenmore dryer from 1979 and when I open the door it just falls down. Is there anything I can do to fix this?
Check the door springs. One or both may be broken. Remove bottom panel and look to the right or left sides for the springs. If broken, just replace the same. One end of the spring hooks into the door hinge assembly and the other end hooks into the base of the frame. You should be able to see a hole in the frame to hook the spring as you will also see a hole in the hinge assembly. Easy fix. Just have to know where to look.
Jan 16, 2010 | Kenmore Dryers
LD-14AW2 door hinge support broken
They are at the sides and back 2 slots to the levers . Vitally
May 12, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
Door hinge spring broken
Yes, it can be fixed. Sounds lilke just a matter of either fixing or replacing hinges/springs.
May 10, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
Broken spring on the gas fuel tank door on Toyota ''Camry'' 1998
Go to your nearest Toyota dealer. Purchase this part number: 77360-22020; approx 4 dollars.
Open the fuel door. Being careful, remove the leftover plastic that is hooked by the door hinge. Insert the new spring assembly under the slot, and press it in until it clicks into place. Very easy to do.
Hope this helps, and thanks for choosing FixYa.
Nov 21, 2008 | 1998 Toyota Avalon
Battery Door Broken
So far, I was able to find a camera like mine on Ebay that was being sold cheap for parts only, because the LCD was broken. I figure that this amounts to probably what I'd be paying if Kodak offered to sell me a replacement battery door (which they do not). Kodak only considers the wrist strap a "user-serviceable item." Maybe so, but I intend to try to fix this myself. If anyone has done this successfully before, please write. Otherwise, will let you know how it goes.
May 06, 2008 | Kodak EasyShare C643 Digital Camera
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
463 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
