Question about Sony STR-DE875 Receiver
Sony STR-DE875 receiver has no sound from right channel front or back. Checked for loose connections & blew out dust, no change
Hy all. I bought a receiver at last week. But the front speakers not working. The rele is jumping just.
i repaired them ! the rele colour is blue. Three percent . left first -Center, between -Surround, between(right Hand)-Front.
I moved the front channel's rele(right hand) .Katt -it sad. Working, volume is back. Rele specification is (colour Blue) Deg Greatings-Ranger of Hungary.Sony STR-DE875 receiver has no sound from right - 10_26_2012_6_50_16_am.jpg
Posted on Oct 26, 2012
  • Ben Johnson
    Ben Johnson Sep 14, 2014
    If you really want to go to town, I flipped the main board over in mine (street find) and resoldered all the relay pins. These amps are notorious for poor soldering quality. A fine tipped iron and steady hand (and magnifier for us with less than steller eyesight) is mandatory.
Problem with SONY STR-DA555ES home stereo receiver popping & going into protector mode
You may have the speakers incorrectly connected or the speakers you are using have an impedence that is too low for the amp to support.
Sep 15, 2013 | Sony STR-DE875 Receiver
Str-de875. Remote is suddenly not making the amp work. the remote still turns tv on/off
does the light blink more than once when you select the 'contol the reciever now' button? I assume you push a button to switch which device the remote will control, and then push another button to astually have the device do something
Mar 09, 2013 | Sony STR-DE875 Receiver
Volume really low, even when turned right up
So the speakers and the individual amp channels work so that lets out the obvious big hardware items.
This is starting to sound like an obscure setting was set or changed by mistake.
It would be nice to figure out what that is/was in case it happens again but you may eventually have to resort to resetting the receiver to factory defaults and start over by holding the1/0 button for 5 seconds.
Mar 04, 2010 | Sony STR-DE875 Receiver
The amps in the receiver turn off and on all the time. The center channel rarely works, and the left & right channels turn off & on every 10-15 minutes as well as the subwoofer output. Is there...
loose connections,issues. disconnect center and front speakers from this receiver. turn on with rear and subwoofer. horrible sound but the point is it will eliminate the speaker issues and confirm loose connection if the receiver continues to behave the way you described.I have repaired a few for loose connections.
Mar 01, 2010 | Sony STR-DE975 Receiver
Quiet front R channel on Sony
Does problem persist when you connect other speaker to front right channel? (i.e. when you connect your FL speaker to FR and vice versa)?
Jul 15, 2009 | Audio Players & Recorders
I have low volume on two channels of my STR DE975 receiver
I been replied you in chat thread, please check and feel free to ask any question.
Aug 20, 2008 | Sony STR-DE975 Receiver
Sony STR-DE595 Sound not balanced
preamplifier or power amp internally but check your signal cables for shorts or breaks,if amp then is internal and needs to be serviced
Aug 13, 2008 | Sony STR-DE595 5-Channel Amplifier
Sound turns off for Sony STR-DE875 amp
If you do not here a click as soon as the power is turned on, (note you must be in a very quite environment no noise absolutely to hear this) then the amplifier has blown output transistors which are pushing DC current to the speakers.
Aug 31, 2007 | Sony STR-DE875 Receiver
Sony Receiver has little sound on radio stations
have you adjusted your sound settings while in listening to the radio mode?
Jul 30, 2007 | Sony STR-DE875 Receiver
Sony STR-DE875 Receiver Logo
878 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
