Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Oil is fine, runs fine for about 10 minutes then bogs down and dies. Let it sit for 10 minutes it will start again and run fine for another 10 minutes. Used to be 20 minutes, then 15. The cooler the weather the longer it runs. Is there some electrical component that may be getting weak? 17.5 hp Briggs. Air cooled. Air filters have been changed but didn't help. Plug wire?About 5 yrs old. Help - It's taking six hours to mow...........
  • 183 Answers
It could easily be an electrical issue, or not. Get a spark tester (hooks up to the spark plug). Pep boys, Autozone, and Napa all sell them for less than $10. Check for spark when the mower has quit. If no spark, most likely need to replace the ignition module. Also check the flywheel key, if it is has been sheared or even knicked, the engine will run hot.
If you still have spark when engine has failed, check the vent on the gas cap. A clogged vent will cause a vacuum to form in the tank and stall the engine.
Posted on Aug 23, 2010
Miller Legend welder. Onan engine starts and runs a few minutes then dies. Why won't it restart for 5 minutes?
Some engines have a low oil cutoff switch. If the oil level drops to a certain point it kills the engine. Your oil level may be close enough that after starting and running for a little bit the level drops enough to kill the motor. After sitting for awhile the level rises enough to allow the engine to run again check the level and add oil if necessary.
Hope this helps.
Bob
Oct 22, 2015 | Onan Starter for twin cylinder engine...
Why did the motor die while I was driving down the road when I turned on the a/c and fan?
If the engine overheated then the antifreeze may be getting into the engine, indicating a cracked head or block. check for water in oil via dipstick. .
May 12, 2014 | 1993 Honda Accord
Why is my carb bogging out on acceleration?
check the air filter or try running it with the lid off the airbox
May 04, 2014 | ATVs
1989dodgeram4x4d100fuelproblem
I own a 97 crew cab dodge ram. I had that issue the computer at my work said o change o2 sensor on exhaust. it fixed it.
simply flooding motor.
Mar 29, 2014 | Cars & Trucks
Engin runs fine for about twenty minutes then quits. oil level is full
try and run it with a loose gas cap the vent could be clogged then check for spark when the engine dies or even better get a inline spark tester then you can see it when its dieing
Jul 12, 2012 | Garden
Engine starts and idles, give throttle, revs, bogs, revs, bogs
Check for a loose connection by the carb. Sounds like its sucking air.
Feb 25, 2010 | Garden
I need help with my 94 cutlass ciera V6!
I AM LEANING TOWARDS A POSSIBLE BAD CRANK POSITION SENSOR OR A POOR CONNECTION IN THE IGNITION CIRCUIT, PERHAPS A BAD IGNITION MODULE. CHECK TO SEE IF YOU HAVE POWER GOING IN THE MODULE AND GOING OUT. ALSO CHECK FOR SPARK WHEN IT IS HOT. I HOPE THIS HELPS. THANKS FOR USING FIX-YA AND FOR AN HONEST RATING. PLEASE FEEL FREE TO KEEP ME POSTED ON YOUR PROGRESS. BEST OF LUCK.
Aug 26, 2009 | 1994 Oldsmobile Cutlass Ciera
Runs fine for a few miles then starts bogging and
it seems the bike is not getting enough fuel if the choke needs to be on check fuel tap or any in line filters
Jun 25, 2009 | kawasaki ZX-6R Ninja Motorcycles
During hot days in summer, car bogs and dies now in spring.
your fuel pump is going.
there was a 10 year unlimited mileage warranty on 2000 focus for this issue, but not sure if 2001 was included. The internal filters in the fuel pump clog and starve the pump. New stlye filters went into prodction but not sure if all of 2001 had the new design.
Apr 24, 2009 | 2001 Ford Focus
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
224 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
