Question about Eureka 12 Amp Capture Vacuum Upright Vacuum
My vacuum won't pick up anything how do I clean it out
  • 694 Answers
1. Replace bag if needed.
2. Check hose/s for clogs. You'll need to detach both ends of the hose, check for visible clogs first, then try to roll a marble through the hose. If it doesn't go all the way through, there's obviously a clog that needs to be removed. Blowing it out with a machine that has an exhaust port usually works for me.
3. Check tube in powerhead and intake on vacuum for clogs. Remove if necessary.
4. Clean filter.
5. Leaky hoses will also cause extreme loss of airflow/suction. No fix for this, except to replace the hose.
Posted on Aug 23, 2010
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Brush doesn't turn all the time
The belt is worn out and you need to replace it. It's slipping and that's what you smell.
Nov 13, 2011 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
Vacuum runs but does not pick up dirt
Have you cleaned the washable filter. Perhaps your cyclones are clogged. you can clean the cyclones yourself. check out this video http://www.youtube.com/watch?v=2OO3ugkyzxk
Jul 10, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuum won't pick up
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 28, 2010 | Dirt Devil Vision Turbo W/Bonus Upright...
Does not have any suction to pick up
Clean out the filter in the top of the cyclone chamber
Make sure there are no blockages in the tubes or hoses by checking for vacuum
May 08, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hello, I have the same model. And though it is three years old, starting from the last month, it does not clean anything anymore. Cannot even pick up one single thing from the floor. Every dirt gets stuck...
i know bissell vacuums are very cheap but they should last more than 3 years. there should be two parts to the dirt cup. remove the dirt cup and above it there should be a round plastic part. unscrew it and check that filter.
Apr 06, 2009 | Bissell 6594 PowerForce Bagless Upright...
Looud noise and no suction
the motor impella is blocked. you have to access this from the bottom
Jan 23, 2009 | Kenmore 34720 Upright Vacuum
Eureka 12 Amp Capture Vacuum Upright Vacuum Logo
145 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
