Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
Difficulty in turning a single handle faucet from side to side. Under the sink there is a barrel shaped weight that has come off and appears to have been wrapped around one of the hoses. Your assistance is appreciated.
    President:
  • 2,559 Answers
The reason it is hard to turn from side to side is the top nut located under the lever is too tight and the the weight does go around the flex line that leads to the faucet but is only the to pull the sprayer back in place.
Posted on Aug 23, 2010
Bathroom sink single handle danze faucet. I removed set screw, but the handle won't come off. How hard can I pull?
Alot of variables there. If it's really old you must be extremely gentle. I have had them crumble into pieces in my hand. If it doesn't appear corroded around the edges and is in good shape, you should rock or pry gently with a non marring tool (putty knife covered by rag) alternating sides to break it loose. A penetrating oil like PB blaster can be used if you can let it sit for a day. Just straight pulling is not wise. Tapping (not pounding) can be helpful. You are just trying to break the bond between surfaces so the vibration of lots of light tapping will sometimes do it.
Jun 09, 2016 | Danze D203112 Melrose Single Handle...
I have an american standard bathroom faucet. Single handle. It is leaking where the faucet meets the sink. I do not see any screws to take off the handle. How do I fix it?
First, turn off the water supply under the sink. Next, put the faucet lever in the up position, no water should be coming out. While in the up position turn slowly while looking at the underside of the handle and you should be able to find a set screw. It will probable be an "allen head" type and you will need and allen head wrench to loosen it. An allen head looks like a hex shape, 6 sided I believe and is rod shaped. If you don't have one they come in sets at your local hardeware.
Jul 16, 2010 | American Standard - Lavatory Faucet -...
Moen faucet removal
you will have two mounting nuts at each end and two water line to disconnect for removal under the sink on any faucet made
Feb 13, 2010 | Moen 7310 Legend Single-Handle Kitchen...
I need to know how to remove the ''washer'' that holds the kitchen faucet in place from under the sink. It looks like a horseshoe type of affair.
most times the retainer nut can be turned by hand or pliers and there is also a tool made to remove them
dont remeber the tools name but it has a crown on top and is tube shaped.
Jan 11, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
The pullout faucet wobbles when returned to the base.
check that nothing blocking hose return weight under sink
Oct 06, 2009 | Danze D405058 Parma Single Handle...
Leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
Sep 25, 2009 | Danze D403412 Melrose Single Handle...
Difficulty shutting off faucet after installation of cartridge
sounds to me like you did not engage handle properly the moen has like a half moon in handle that has to go on just right and can be a little tricky if it went on easy its not on right
May 03, 2009 | Plumbing
Dripping faucet
Moen is a cartridge style unit. They make two different cartridges that you can buy at Home Depot. Turn the water off under the sink and then remove the handle. You will see the the cartridge. It has a U shaped retaining clip that pulls out. Once you remove it, then take a pair of pliers and pull the cartridge out. Take it up to HD and match the one you have. The new one will slide right back in and you will reverse the process.
Mar 15, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
439 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
