Installation manual for Toshiba KFR66-GW Air Condition Unit
Enigma SLR61-GW. System runs for about 30 mins and then shuts down and a status light blinks 4 times.
Open the front end of the blower.
You will find tow filters that slide out.
Clean them with water and replays them.
Go to the outside one, take a hosepipe and run a strong stream of water thru the radiator until its clean.
This will solve your problem.
Good luck.
Oct 23, 2015 | Heating & Cooling
I have a goldstart gw 6500 the remote is not turning the unit on how can i fix it?
check battery in remote clean remote sender and a/c receiver replace remote
Jul 14, 2014 | Goldstar M5200R Air Conditioner
Where can I find a Toshiba 1600ep UPS fatory repair manual?
You can not obtain a factory manual. You need to get certified to get that. Toshiba are very strick with their product.
Jun 19, 2012 | Toshiba Computers & Internet
Unit will not turn on. Power cord is fine. Power is on to the unit. Breakers are not blown
If this has the new digital type controls its possible the board has failed, I've had many come into my shop like that. Not much you can do as the parts tend to be too high vs cost of a new one
Jun 22, 2011 | Goldstar GW-HD5000 Window Air Conditioner
Please, some solutios for the failure f8 I need, air condicioner 12000 btu
The F8 code usually is because of a low charge condition...get the unit checked for leaks and recharged...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Nov 21, 2010 | Office Equipment & Supplies
Unit turns on no cool air comes out even when setting is on high
1 Please remove th back cover and check if the cooling pipes are getting cool when the air conditioner runs. If there is no cooling /moisture deposit on the pipes it means there is no gas in the air conditioner. Get that checked up. Refill the gas after getting checked up that there is no leakage.
May 31, 2010 | Goldstar GW-HD5000 Window Air Conditioner
Installation details required
I had a look at a similar unit that was already in-situ.
Feb 09, 2010 | Heating & Cooling
Casio G-Shock GW-300 replacement bands
I have a Casio g-shock gw-330a and now find myself again replacing the band. So far, $60 on bands. They last me two or three years. To install the band, take the band and watch to a Jeweler. My local Sears does it for me. $5 for installation; $5 for purchase shipping; $20 for band. $30 every couple of years.
This cost disturbs me.
Jun 09, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Epson r230
www.fixyourownprinter.com
Dec 25, 2007 | Epson Stylus C46 InkJet Printer
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
