Machine not emtying. washed a rubberised bath mat which disintigrated during washing. I think the filter is blocked. where do I find it on this particular machine
  • lwaycy Aug 23, 2010
    I am still trying to get assistance to a simple question. Where is the filter located on my GE Super Capacity Plus. 10 cycle. Front loading washing machine. Model No GCRH410F 2WW.
    I washed a rubberised bath mat tha disintegrated in the machine. I think it blocked the filter as the machine had worked perfectly before this
    Hi I looked at all three of these sites, two I had visited previously and they were no help for my particular machine. I just really need to know where the filter is so I can try that first. My machine is a GE Super Capacity Plus Front Load 10 cycle washer. Model number GCRH410F 2WW
  • Washing Mach... Master
  • 43,501 Answers
I see nothing that tells me what make or model machine you have...
I think you are probably right and your filter is a mess...
Here is a generic tip that I wrote about the filter plugging problem that will probably steer you in the right direction...
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Aug 23, 2010
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow links to diagnose your problem…
http://www.washerhelp.co.uk/diy-repair-help_3.html
http://www.ehow.com/how_5030854_fix-machine-not-drain-spin.html
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itwontdrain
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
I had put bath mats for washing the rubber came off blocked and all water came out at bottom opened the nub and cleaned it restart machine but still blocked
You need to remove the filter and clean same ,its located middle bottom of machine or bottom left, suggest this checked first may need several cleans to work.....
Jun 13, 2011 | Hoover Washing Machines
MACHINE NOT EMTYING WATER , BUT NOT ON ALL WASHES. DOES ON A FEW AND THEN WILL STOP. CANNOT REMOVE FILTER TO CHECK IF BLOCKED.
"Cannot remove filter" - that's a good sign it IS blocked.
Tipping the machine on its side or back may cause debris to move, allowing you to unscrew the filter.
Alternatively, remove the pump motor from the housing (tools needed) and clear blockage.
Feb 27, 2010 | Washing Machines
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
We think we overloaded the machine with bath mats and since then the water did not drain and the machine does not work any more. All buttons are flashing.
your pump is totaly clogged with the math matt sand
you should be able to access the pump from the rear wall,
bring towels you will loose water
remove both hoses from the pump and ensure they are clear, wash the drain hose completly run water through it
make sure you pump is clean and free
to spin
reassemble and and plug back in
errors should clear
Oct 23, 2009 | Washing Machines
Rubber mat flakes in washer
it will cause a clogged pump
take off the back wall
you will see the pump
unplug it
ctake off the two hoese( make sure botha re clear)
ensure pump is clean
reinstall and you should be ok
Oct 04, 2009 | GE WCVH6260F Front Load Washer
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
I have a bath mat that I washed in my duet washer successfully twice. Now when the cycle is complete the bath mat is drenched and apparatly no water was extracted from it. I'm frustrated. Another frequent...
Out of balance with wet, heavy rug.
Bathmat is border-line on being excessively heavy (wet)
Do not use in washer. The fact that you got away with it before is your hint NOT to do this again or else bigger problems???
Apr 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Maxx (ref WFL 2450). stopped during wash and switch on
Remove the front lower panel, screws underneath. Drain off water. Be prepared for more water. Check filter for clogging. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if it is any shorter than 5mm replace brushes.
Apr 01, 2009 | Bosch Washing Machines
Dark Spots on clothes
There may be some pieces of mat stuck between the inner and outer drums. The quickest way to remove this is to remove the drain hose that leads from the drum to the pump and feel around the bottom of the outer drum and remove any foreign objects that may be stuck in there.
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
