Question about Memphis 16MC11100 Car Amp
The fuse fault light is on - Memphis 16MC11100 Car Amp
Tail lights not working
Not for tail lights.
GeT a 12 Volt probe screwdriver with the handle that lights up or volt meter. Remove the bulb turn on tail lights clip to any good ground and put the probe tip on the bump at the bottom of the socket and it should lite up. Now clip ground to side wall of socket and probe both bumps in the center one bump is tail the other is brake. Have someone push on brakes and see if they light when on one bump then check tail on other bump. DO NOT TOUCH THE SIDE WITH CENTER PROB OR IT WILL SHORT BE CAREFUL. this will tell you where the problem is,
Also check fuse holder.
leave fuse in clip to ground turn on tail light and probe both ends of fuse for power.
Hope this helps Mike
Mar 03, 2016 | Cars & Trucks
Took the abs fuse out of 1995 saturn sw2 but light stays on
the light is there as a warning to show it has a fault and as such if you remove the fuse it has a fault
Mar 13, 2015 | Saturn SW2 Cars & Trucks
Testing a headlight relay t-100 Toyota 95
If the ALT FUSEand TAIL FUSE are good, the taillight relay may have failed. If the STOP FUSE is good, the stoplight switch may have failed.
Mar 31, 2014 | 1995 Toyota T100 Xtracab
Fuse for tail lights keeps blowing
You have a serious short circuit in the wiring to the tail lights. Fuses protect the wiring in your vehicle from catching fire.
You need to trace the tail light wiring from the fuse box to the tail lights to locate the fault/short circuit.
A wiring diagram can help as it shows the colour code of the wires to the tail lights.
This problem can be difficult to trace and you most likely need an auto electrician to fix this problem. It could mean installing a new wire to the tail lights as a quicker fix and bypass the fault..
Apr 19, 2013 | 1993 Nissan Quest
Hello , I have a new Tiguan trend and fun 2.0 and my dash light and radio won't work.
Check the manual and find the fuse box or boxes. find the dash lite fuse, it may say " interior illumination" If it is good check also the radio fuse.
If the fuses are good, you have to visit a wv dealer for detailed fault finding.
If the car still have warranty, don`t mess with the electrical system.
The car also have can bus electrical system, and it can go wrong when you try to fault find your self.
The fault could be the light switch, fuses, the radio.
Here is a fuse list for a golf:
http://mit.edu/dennis/www/vw/fuses.html
Check the Fog light relay, instrument panel light dimmer switch fuse.
Good luck
Jan 08, 2013 | RupseTM For VW: New BORA / PASSAT CC /...
I have a 2005 Kawasaki z750s. Both headlights went out at the same time. My tail lights and all dash lights work. Is it a fuse or wiring?!
Possible water damage to head light relay in the fuse box under the seat or the stator which controls the head light relay. Get a auto electrician to do an trace check on the wiring & connections to rule out all other faults. If the lights cut out after an heavy bump and come back on after a set time, the fault could be the relay or stator. Have the auto electrician resolder the relay connections in the fuse box (about 40 connections), also have an 12v LED warning light fitted to the stator connections with enough wiring so the LED can be mounted on the handle bar. If the LED cuts out the stator is at fault(very costly), if the LED stays on the head light relay is at fault. Also better waterproof the standard fuse box , the case is not that waterproofed (easy done with insulation tape). Hope this helps.
Dec 11, 2011 | 2008 kawasaki Z750
Fault light is on all the time. Is there a fuse ?
Hi:
No there is no fuse for the fault light. Fault light it's on only when:
1) Voltage is wrong or not enough.
2) Overheated machine and needs to cool down.
3) Your airflow is too weak.
Check your owners manual section 5 for more info.
Sep 07, 2011 | RTO Esab Power Cut 650 Plasma Cutter W/25'...
Hi i have an 1986 toyota 4runner the dash lights and running lights stopped working... fuse is blown and checked wires in the tail lights, marker lights and behind the dash with no luck... is there a...
The tail and marker lights and Instrument lights are on the same circuit so both will go out if the fuse for this circuit blows. If fuse continues to fail, check the tail light or marker globes, including the globes for the number plate, for a globe that may have an internal short causing the fault and replace as necessary. As you have already checked the wiring near the light fittings for any chafed wires that could be shorting to the body causing the fault, then a closer inspection of the wires inside all the light assemblies for any shorts may be needed.
It could also be that the instrument dimmer control has failed and is causing the fault. The electronic bits inside the dimmer control for these lights sometimes go faulty. Try disconnecting the connecting plug on the rear of the dimmer control and checking if fuse still blows. If fuse continues to fail, then the fault in the tail and marker lights circuit.
Remove all the tail, number plate and running light globes from the light assemblies and leave the instrument dimmer control disconnected and check if fuse still blows.
Disconnect the plug near each of the light assemblies to see if any of the individual assemblies is causing the fault. With all light assemblies disconnected and fuse continues to fail, then the fault must be in the main wiring loom some where.
If you have a Multimeter, it could be used to determine which light assembly has a fault between the lamp supply and earth connection.
Feb 25, 2011 | 1987 Toyota 4Runner
I hooked up a trailer to my 04 dodge 2500 (5.7 ltr) and when i plugged in the lights my truck lost all running lights and tail lights. headlights still work and so do turn signals. I checked all the...
your vehicle has a "integrated power module". its a fancy name for a smart fuse box. What likely happened is there is a problem with the trailer wiring. The power module detected the fault and shut down the running lights. The power module will need to be reset at the dealer.
Fuse 15 is a 50 amp fuse for the park lamp relay
Fuse 32 and 34 are 10 amp fuses for the right and left park lights
Fuse 33 is a 10 amp fuse for the trailer park lights.
After it is reset I would not plug in the trailer until the fault is located and repaired.
Oct 12, 2010 | 2004 Dodge Ram
Hello have a HS2800 the two yellow lights are flashing....and I found a wire with a fuse in it and can't find where it plugs into...can anyone help
the wire with the fuse belongs to external light fetures (unit does not have. It was intended for future use for external ligts)
the two yellow lights endicate problme with batteries( too low) or the module controller.
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul
8. Power Module Faul
9.Shark Module Faul
****two yellow lights*** Module problem
Contact me Direct 909-590-1388 x115 CTM HOMECARE OFFICE
Sep 17, 2009 | Ctm HS-2800 Power Wheelchair
Memphis 16MC11100 Car Amp Logo
101 people viewed this question
Top Memphis Car Audio & Video Experts
Tygh Duval
Tygh Duval
Tom Chichester
richard foulk
Are you a Memphis Car Audio and Video Expert? Answer questions, earn points and help others
