Question about Maytag CWE5800A Electric Double Oven
Maytag oven beeping the message F2/F3 and I do not know what is causing it to do that. What is the cause, and how do i fix it?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F2/F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 27, 2010
  • boris_gorshk
    boris_gorshk Mar 14, 2013
    unplug the oven and then plug in again. it will resolve the issue.
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
F2 and F3 messages - shuts itself off. Any idea of what it is and how to fix it?
Hi
F2/F3 error message relates to the oven temperature sensor or thermostat faults.
The fix is normally to replace it.
This link may help if you want to do it yourself
www.wonderhowto.com/how-to-replace-cooker-thermostat-oven-250012/
Hope you get it fixed.
Dec 16, 2010 | GE JKP15 Electric Single Oven
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
I have a Jenn Air Oven that quit working. It
HI - The code described, F3 then F2 both correspond with indicated failure of the temperature sensor. This is a fairly inexpensive part and is easy to replace. The normal resistance of the sensor is 1000-1100ohms. Worth fixing for sure. Complete model number from tag on unit will be needed to get correct part. Let me know if this info helps- have more if needed- Thanks-  Ed
Mar 16, 2010 | Jenn-Air Ovens
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
F2,F5,F7 message
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Feb 07, 2009 | Maytag MEW5527B Electric Single Oven
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag CWE5800A Electric Double Oven Logo
249 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
