Question about Lincoln Electric - Pro-Cut 80 Amp Plasma Cutter
I'm interested in buying a used Pro Cut 80 that on the inside of welder says 460/ 580 volt ? connection. Can this welder be converted to 240 volts? What if its connected to 240 volts. Will it work? Thanks
  • Bryan Fullerton
    Bryan Fullerton Aug 23, 2010
    In case nobody answers you I think I can help a bit. However I used the clarification to avoid a decrease in my ratings. Too often people dont even try to answer a problem for fear their rating will drop.
    Regardless to answer your question somewhat. If that unit has a big heavy transformer then it is possible to replace it with a 240volt one and it would work. If it uses newer inverter style technology then the system board would have to be replaced.
    If you tried to use it on 240 voltage, and it worked, its output would be low. In other words it would not work at 80 amp performance.
    I have a much smaller unit that will work either 220 or 110. These things are very sensitive in the area of electronics. Even a small problem with the tip and they quit working.
    If I was you and the price was a very good deal Id ask the owner to verify that it would work at 240. If he wouldn't then I wouldn't buy it. I honestly do not think it would work on 240 volts. But I doubt many with cutting experience on here would know either. Which is why I went to the trouble to give my thoughts on it.
    I cut and weld and have some knowledge of electronics and that is what I base my suggestions on.
    Good luck chief.
  • 760 Answers
I doubt it. You will need the model number to determine for sure. There are two models that are listed for 460/580 with no mention of other voltages. Get the exact model number and you can download a manual at: http://www.mylincolnelectric.com/Catalog/lecooperatorsmanualsearch.aspx
Posted on Aug 27, 2010
Howw do you make a Samsung bd-F5700 blue ray player operate on a 240 volt power supply
You'll need to bring the voltage down to 110-120 volt. Travel converters do this cheap and effective. The player only uses 12 Watt according to the manual. You could use an old 3 prong extension cord to cut of the connector to connect to your power supply. Get the converter below and plug it into the adapter, who then will fit in the extension cord.
25361686-pcx3svhkvlazjixsdsr3jt1v-2-0.jpg New 220V to 110V Step Down Voltage Converter 50W Travel Power Transformer 25361686-pcx3svhkvlazjixsdsr3jt1v-2-3.jpg Generic Round Europe to USA Plug Adapter
Jan 09, 2015 | Samsung Televison & Video
How do you switch from 240 volts to 115 volts on magnum force pump
Is the motor a Dual voltage capable motor?
If so, the diagram for voltage change should be on the label.
It is also on the inside of the back cover were the wiring comes into the motor.
Most likely it is an AO Smith Motor that Jacuzzi used for their pump. The newer motors today are really easy to switch between voltages. There are 3 male spades on the back of the motor and a wiring plug with 2 female connections. You should easily see a diagram/bold arrow, for which 2 connections/spades are for 240 and which 2 for 120. Just lift and move the plug to one side or the other. 1 spade will not be used.
Take a look at the picture:
May 23, 2014 | Jacuzzi Pool & Spa
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
How to make a miller master 175 from 480v to 208v or a regular house outlet.
You can't convert a 3 phase transformer to single
phase 240 volt
208 volt is strickly 3 phase
May 23, 2011 | Miller Welding Tools
Hello i have a Sony Vaio PCW-W2 that i brought to canada from uk. how do i switch voltage to 110?
u can find voltage converter connectors......try using that....u can ask for travel adapters....hope u find them
Mar 08, 2010 | Sony Computers & Internet
Ave a power mate 225 amp 240 volt welder that wont arc
Sounds to me like the Power Controller has gone bad. These are a real tricky, dangerous, things to fix yourself, I recommend that you call the service rep, for Power Mate,and cut your losses.
Feb 24, 2010 | Welding Tools
I need to convert this welder to operate on 400 volts,it currently operates on 240 volts,i have no tap diagram,can anyone help?
400 is a very odd voltage. You could use a stepdown transformer from 400 to 240, but that would be a very large transformer no matter what voltage you are starting at.
This must be a European or other country as the common USA voltages are 120, 240, 277, 480, 660 fior example.
Aug 12, 2009 | Welding Tools
Need to convert my 110 volt 15amp to 240 volt
You can buy a transformer which allows all 110v power tools to work from a 240v supply. You will also need to change the plug on the compressor to a yellow 110v type. You can buy transformers for around £25 and around £3 for the plug
Mar 29, 2009 | Craftsman Air Tools & Compressors
Lincoln Electric - Pro-Cut 80 Amp Plasma Cutter Logo
98 people viewed this question
Top Lincoln Welding Tools Experts
Steve
joe2639
Level 1 Expert
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
